Sending data from WiFi module to Teensy, looking for alternatives to I2C
Hi all!
New to Arduino!
I am using Teensyduino IDE 1.56on MAC OSX Monterey.
I have a Node MCU V0.9 ESP8266 which connects as a client to my phone's hotspot. I use it to read the RSSI value (signal strength) of the connection and map this value to a new range (0-255).
I want to send that value every 200 millis to my Teensy board (Teensy 3.2), read it and use it to modulate the frequency of waveform 1.
What i tried: I set up an I2C communication where the NODE MCU is a Master - Sender and the Teensy is the Slave - Receiver.
That works, however, I get no sound coming out while the I2C is running. Seems like the I2C blocks my void loop() and is not the appropriate method to achieve this. I am therefore looking for another way to send this value.
What could work? I read that PWM is too eratic (https://arduino.stackexchange.com/qu...via-analog-pin)
Could this be done using software Serial?
What is the most reliable way to do this?
My code below:
1 - On the Node MCU side (I2C master + Sender for now)
//CODE FOR THE NODE MCU = NODE MCU is a Master - Sender
#include <ESP8266WiFi.h>
#include <Wire.h>
const byte SlaveDeviceId = 1;
  pinMode(LED, OUTPUT);
  pinMode(SIG, OUTPUT);
  pinMode(ON, OUTPUT);
  digitalWrite(ON, HIGH);
  WiFi.mode(WIFI_STA);
  WiFi.begin("SSID", "pw");  // Try to connect to a given WiFi network
  Wire.begin(D2,D1);
  printWiFiState();
  int map_sig = dbmtoper();
  int input = map_sig;
  // Send two bytes to slave.
  Wire.beginTransmission(SlaveDeviceId);
  Wire.write(input >> 8);
  Wire.write(input & 255);
  Wire.endTransmission();
  delay(200);
void printWiFiState() {
  static boolean printed = false;
  if (WiFi.status() == WL_CONNECTED) {
    if (printed)
      return;
    printed = true;
  } else {  // if WiFi is not connected
    if (!printed)
      return;
    printed = false;
int dbmtoper() {
  int best_rssi = -20;
  int worst_rssi = -70;
  if (WiFi.status() != WL_CONNECTED)
    return 0;
  int dBm = WiFi.RSSI();
  // Serial.println(dBm);
  if (dBm <= worst_rssi)
    return 0;
  if (dBm >= best_rssi)
    return 255;
  return map(dBm, worst_rssi, best_rssi, 0, 255);
And on the Teensy (receiver - slave for now)
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SerialFlash.h>
// GUItool: begin automatically generated code
AudioSynthWaveform       waveform1;      //xy=186,238
AudioOutputAnalog        dac1;           //xy=523,243
AudioConnection          patchCord1(waveform1, dac1);
int receivedValue;
  // Audio connections require memory to work.  For more
  // detailed information, see the MemoryAndCpuUsage example
  AudioMemory(12);
  waveform1.begin(0.1, 440, WAVEFORM_SINE);
   // Start I²C bus as a slave
  Wire.setSCL(19);
  Wire.setSDA(18);
  Wire.begin(SlaveDeviceId);
  Serial.println("uploaded");
  int freq = map(receivedValue, 0, 255, 100, 500);
  waveform1.frequency (freq);
  delay(200);
  Wire.onReceive(receiveCallback);
// aCount is the number of bytes received.
void receiveCallback(int aCount)
  if(aCount == 2)
    receivedValue  = Wire.read() << 8;
    receivedValue |= Wire.read();
    Serial.println(receivedValue);
    Serial.print("Unexpected number of bytes received: ");
    Serial.println(aCount);
Thank you!
both appear to have hardware serial ports? e.g. teensy32 and NodeMCU
The Teensy yes, for the Node MCU, which one should I connect it too?
NodeMCU pin D4 GPIO2 is TXD1 - Serial1 Tx
so long as you are only transmitting from NodeMCU to Teensy no problem
RXD1 appears to be missing
Thank you!
How would i go about if I wanted to have several NOde MCU sending value over serial?
And, does this mean i should use the Software serial library?
the Teensy appears to have three hardware serial ports available - will that be sufficient?
once you beyond that you could use RS485
doubt about using software serial on the tensy as it could upset your waveform timing
