Sending data over udp in larger packets
currently i send a struct over udp like this from esp32 to esp8266,
  Udp.beginPacket(custom, 4210);
  Udp.print("ALDATA");
  Udp.write((uint8_t*)&ts1, sizeof(ts1)); //cast to bytes
  Udp.endPacket();
the size of ts1 is 262 bytes, When i send this message it seems like slow transmission, and slow receive. How can i speed this up. if i try to send like this would it send larger chunks?
  Udp.write((uint32_t*)&ts1, sizeof(ts1));
  Udp.endPacket();
I also need help understand the variable size between arduino mega and esp32. If i make a struct on arduino mega,
struct test {
uint8_t a;
test t;
then i try to send it to the esp32 over serial,
Serial2.write((uint8_t*)&t, sizeof(t));
but when i receive it on the esp32 the struct size on the esp32 dont match the arduino struct and the struct is corrupted.
type or paste code here
I figured out why it was going slow, i was reading *39 uint32_t " 1248 bytes into a 255 byte buffer..
The problem with the variable sizes between the two cpu's is still a problem. i have a chart that explains the difference between arduino cpu's. but i cant seem to find a chart that explains the esp32 or 8266.
the simplest thing is to run a program to print the sizeof() a type, e.g.
  Serial.println(sizeof(int));
void loop() {}
gives
ESP32 4
esp8266 4
Arduino Mega 2
when transferring data between systems in binary as well as the sizeof() of different types one may have to consider the endianness
Thanks i had not thought about that. Good idea
