This is not a question, it's some code I already have working correctly. I originally started working on it as part of some discussion on this YouTube video, but I'm posting it here because I think it's a generally useful example, and this is a better place for people to find it than from YouTube comments.
This code sends a data structure (32 bytes maximum) between nRF24L01 modules in a one-way connection. The actual data values being sent in this example are not set with anything important, but you could set them with values from sensors etc. As a simple check to make sure the values are being received correctly, just one float value is set with a slowly increasing value.
On the sending side, the time taken for the write() call to finish is used as an estimate of whether an ACK was received for that packet. Each packet is given an id so that the receiving end can tell how many packets it missed.
Each side prints out some stats like this:
Read 1000 packets, last id = 62080, float0 = 30.922140, skipped = 1, 680 packets/sec (21 kbyte/sec)
Read 1000 packets, last id = 63081, float0 = 31.422619, skipped = 1, 678 packets/sec (21 kbyte/sec)
Read 1000 packets, last id = 64083, float0 = 31.925575, skipped = 2, 506 packets/sec (16 kbyte/sec)
This code could be useful for checking the quality of RF connections.
To use it, change the 'sender' value to true and upload to one Arduino, then set it to false and upload to the second Arduino.
Sending formatted data packet with nRF24L01.
Maximum size of data struct is 32 bytes.
1 - GND
2 - VCC 3.3V !!! NOT 5V
3 - CE to Arduino pin 9
4 - CSN to Arduino pin 10
5 - SCK to Arduino pin 13
6 - MOSI to Arduino pin 11
7 - MISO to Arduino pin 12
8 - UNUSED
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
// For printf support
int serial_putc( char c, FILE * )
Serial.write( c );
return c;
const uint64_t pipe = 0xE8E8F0F0E1LL;
RF24 radio(9, 10);
// The sizeof this struct should not exceed 32 bytes
struct MyData {
byte byte0;
byte byte1;
byte byteArray[2];
int int0;
int int1;
int intArray[2];
float float0;
float float1;
float floatArray[2];
unsigned long packetId; // 16 month rollover at 100 packets/sec
// Change this when uploading to each Arduino
boolean sender = true;
// Print some info to serial after this number of packets
unsigned long printRate = 1000;
fdevopen( &serial_putc, 0 ); // for printf
// Set up radio module
radio.begin();
//radio.setDataRate(RF24_2MBPS); // Both endpoints must have this set the same
//radio.setAutoAck(false); // Either endpoint can set to false to disable ACKs
//radio.setPALevel(RF24_PA_MIN); // Power amplifier level. Also LOW,MED,HIGH (default is HIGH)
radio.printDetails();
if ( sender )
radio.openWritingPipe(pipe);
else {
radio.openReadingPipe(1,pipe);
radio.startListening();
int dataSize = sizeof(MyData);
printf("Size of MyData: %d\n", dataSize);
if ( dataSize > 32 )
printf("*** MyData struct is too large ***\n");
printf("This Arduino is set to be a %s\n", sender ? "sender" : "receiver");
unsigned long nextPacketId = 0; // Stamp packets with their sequence
float floatSensor = 0; // A fake 'sensor' so we can see some data changing
unsigned long unAckedPackets = 0; // To estimate how many packets were not ACKed
unsigned long lastPrintTime = 0; // To measure time between printouts
void sendData()
MyData data;
// Set properties of your data here...
data.float0 = floatSensor;
data.packetId = nextPacketId;
// Record a before and after time to see how long the write takes
unsigned long beforeWrite = millis();
radio.write(&data, sizeof(MyData));
unsigned long afterWrite = millis();
// Although the RF24 documentation states that the timeout for
// receiving an ACK is 60ms, in my experience it seems to wait
// for only about 2-3ms. The value 2 here was chosen by printing
// out the time taken for 1000 writes when the receiver was non
// existent (ie. all packets dropped) and this was around 2788ms
// between two Arduino UNOs. So I figure that any writes taking
// 3ms or more have likely been abandoned without receiving any
// ACK. Note that this does not mean the packet was not actually
// received at the other end, it just means that the sender could
// not confirm that the packet arrived.
if ( afterWrite - beforeWrite > 2 )
unAckedPackets++;
// Every n packets, print out some info
if ( data.packetId % printRate == 0 ) {
if ( data.packetId > 0 ) {
// Use bytes/msec as an approximate kbytes/sec value
unsigned long now = millis();
unsigned long packetsec = ((printRate - unAckedPackets) * 1000) / (now - lastPrintTime);
int kbsec = (sizeof(MyData) * (printRate - unAckedPackets)) / (now - lastPrintTime);
lastPrintTime = now;
// Format the float for printing
char buf[16];
dtostrf(data.float0, 0, 6, buf);
// As mentioned above, the dropped count is only a rough estimate.
// You may see some non-zero values even when no packets were really
// dropped, but it's not bad as a rough guide. You may need to alter
// the value 2 used above depending on the speed of the microprocessors
// you are using, to get a better estimate.
printf("Wrote %ld packets, last id = %ld, float0 = %s, unAcked %ld, %ld packets/sec (%d kbyte/sec)\n", printRate, data.packetId, buf, unAckedPackets, packetsec, kbsec);
unAckedPackets = 0;
// Increment the packet id for next time
nextPacketId++;
// Change the 'sensor' value so we can check floats are working
floatSensor += 0.000001 * random(1000);
unsigned long packetsRead = 0; // Counts total packets read
unsigned long expectedPacketId = 0; // To track whether the packet id was what we expected
int missedPackets = 0; // How many packets missed since last printout
void recvData()
if ( radio.available() ) {
MyData data;
radio.read(&data, sizeof(MyData));
packetsRead++;
// Check if the packet id was what we expected. Unlike for the sender
// this is not an estimate, it's a known value because we can look at
// incoming packet ids to see how many we missed.
if ( expectedPacketId > 0 )
missedPackets += data.packetId - expectedPacketId;
// Set the packet id we will expect next time
expectedPacketId = data.packetId + 1;
if ( data.packetId > 0 && packetsRead % printRate == 0 ) {
int kbsec = (sizeof(MyData) * printRate) / (now - lastPrintTime);
char buf[16];
printf("Read %ld packets, last id = %ld, float0 = %s, skipped = %d, %ld packets/sec (%d kbyte/sec)\n", printRate, data.packetId, buf, missedPackets, packetsec, kbsec);
missedPackets = 0;
if ( sender )
sendData();
recvData();
