Oh yeah
Should have thought of that!
Please have a look at my code and suggest how I could increase the timing of the sensor.
1st sketch
#define NAME “Detect BLE” // no more than 11 characters
#define DEBUGGING DISABLED
#define ACCELEROMETER DISABLED
/ frequency to read sensor values in µs
const unsigned long SENSOR_UPDATE_FREQ = 60000;
const unsigned long IMU_READ_FREQ = 50000;
const double IMU_FILTER_ALPHA = 0.5; //Alpha for accelerometer low pass filter
unsigned long nextSensorUpdate;
unsigned long nextIMURead;
double dt;
const uint8_t BITS[8] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
const uint8_t MASK[8] = { 0xFE, 0xFD, 0xFB, 0xF7, 0xEF, 0xDF, 0xBF, 0x7F };
#include “common.h”
bool connected = false;
BLEPeripheral blePeripheral;
BLEService appinventorService(“E95DFFFF-251D-470A-A062-FA1922DFA9A7”);
#define MODE PREAMBLE
#include “sensors.h”
#undef MODE
#define MODE DEFINITIONS
#undef MODE
#define MODE FUNCTIONS
#undef MODE
#if DEBUGGING == ENABLED
while (!Serial);
#endif
LOGLN(“Starting App Inventor…”);
blePeripheral.setDeviceName(NAME);
blePeripheral.setLocalName(NAME);
blePeripheral.setAppearance(128);
blePeripheral.setAdvertisedServiceUuid(appinventorService.uuid());
blePeripheral.addAttribute(appinventorService);
#define MODE SETUP
#undef MODE
LOGLN(“Setting connection interval”);
blePeripheral.setConnectionInterval(0x0006, 0x0010);
LOGLN(“Begin peripheral”);
blePeripheral.begin();
Serial.println(“App Inventor started.”);
BLECentral bleCentral = blePeripheral.central();
if (bleCentral && !connected) {
Serial.print("Connected to ");
Serial.println(bleCentral.address());
connected = true;
} else if (connected && !bleCentral) {
Serial.println(“Disconnected”);
connected = false;
if (connected) {
if ((long)(micros() - nextSensorUpdate) >= 0) {
updateSensorValues();
nextSensorUpdate += SENSOR_UPDATE_FREQ;
#if ACCELEROMETER == ENABLED || GYROSCOPE == ENABLED
if ((long)(micros() - nextIMURead) >= 0) {
updateIMUValues();
#endif
void updateSensorValues() {
#define MODE UPDATE
#undef MODE
#include “imu.hh”
#endif
2nd sketch
#if MODE == PREAMBLE
#include <CurieIMU.h>
#define ACCELEROMETER_SETUP setupAccelerometer
#define ACCELEROMETER_UPDATE updateAccelerometer
#elif MODE == DEFINITIONS
struct AccelerometerData {
float x;
float y;
float z;
volatile struct AccelerometerData accel;
BLEService accelerometerService(“E95D0100-251D-470A-A062-FA1922DFA9A7”);
BLECharacteristic accelerometerReadChar(“E95D0101-251D-470A-A062-FA1922DFA9A7”, BLERead | BLENotify, sizeof(AccelerometerData));
void setupAccelerometer();
void updateAccelerometer();
float convertRawAcceleration(int aRaw);
float convertRawGyro(int gRaw);
#elif MODE == FUNCTIONS
void updateAccelerometer() {
// accel is computed in updateIMUValues in imu.hh
accelerometerReadChar.setValue((byte *)&accel, sizeof(accel));
void setupAccelerometer() {
CurieIMU.begin();
CurieIMU.setAccelerometerRange(4);
CurieIMU.setGyroRange(250);
// Configure initial values for characteristics
LOGLN(“Calibrate sensors”);
calibrateIMU();
updateIMUValues();
#if !ONE_SERVICE
Serial.println(“Configuring Accelerometer Service…”);
blePeripheral.addAttribute(accelerometerService);
#endif
blePeripheral.addAttribute(accelerometerReadChar);
#elif MODE == SETUP
#elif MODE == UPDATE
#endif
#endif
Please provide some suggestions.
Thank you
