Hi!
I want to read the XYZ angle of an MPU6050 sensor and send these three numbers to a server as fast as possible.
I have tried the ESP8266WiFi library basic HTTP client example and I was able to send a get command and receive a response from the server. but once I import the example codes to my main code (reading the sensor data), the speed of the ESP reading the data will decrease noticeably, even if I change the reading intervals from 10ms to 150ms, I still get data every 1 or 2 seconds. note that I haven't sent any data to the server yet, and it's still the same "send get, receive OK" in the example.
I don't know if my approach is completely wrong or if I'm doing something wrong along the way.
I would also like to know if there are other libraries that could do this task for me.
anyway, here's my code:
1- the HTTPClient example just in case you want to read it:
BasicHTTPClient.ino
Created on: 24.05.2015
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
ESP8266WiFiMulti WiFiMulti;
// Serial.setDebugOutput(true);
for (uint8_t t = 4; t > 0; t--) {
Serial.printf("[SETUP] WAIT %d...\n", t);
Serial.flush();
WiFi.mode(WIFI_STA);
WiFiMulti.addAP("MilaFree", "1234567890");
// wait for WiFi connection
if ((WiFiMulti.run() == WL_CONNECTED)) {
WiFiClient client;
HTTPClient http;
Serial.print("[HTTP] begin...\n");
if (http.begin(client, "http://xxx.xxx.xxx.xxx:xxxx")) { // HTTP
Serial.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if (httpCode > 0) {
// HTTP header has been send and Server response header has been handled
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
String payload = http.getString();
Serial.println(payload);
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
Serial.println("[HTTP] Unable to connect");
delay(10000);
2- the HTTPClient inserted inside my code that reads the MPU6050 sensor values:
/* Get tilt angles on X and Y, and rotation angle on Z
* Angles are given in degrees
* License: MIT
#include "Wire.h"
#include <MPU6050_light.h>
MPU6050 mpu(Wire);
unsigned long timer = 0;
Wire.begin();
////////////////////////////// WIFI PART START ////////////////////////////////////////////
Serial.flush();
WiFiMulti.addAP("Set", "set12801");
////////////////////////////// WIFI PART END ////////////////////////////////////////////
byte status = mpu.begin();
Serial.print(F("MPU6050 status: "));
Serial.println(status);
while (status != 0) {} // stop everything if could not connect to MPU6050
Serial.println(F("Calculating offsets, do not move MPU6050"));
// mpu.upsideDownMounting = true; // uncomment this line if the MPU6050 is mounted upside-down
mpu.calcOffsets(); // gyro and accelero
Serial.println("Done!\n");
mpu.update();
WiFiClient client;
HTTPClient http;
if (httpCode > 0) {
http.end();
if ((millis() - timer) > 150) { // print data every 150ms
Serial.print("X : ");
Serial.print(mpu.getAngleX());
Serial.print("\tY : ");
Serial.print(mpu.getAngleY());
Serial.print("\tZ : ");
Serial.println(mpu.getAngleZ());
timer = millis();
