Sending data to a web hosting database
I tried sending the rfid card data with Nodemcu to my web database, but this problem arose when sending. Can anyone tell me where the problem is?
à| üȤlìÉã¬l$øD:nÅüI am waiting for card...
Tap card key: 4E:66:C8:75
requesting URL: belajar-hosting.xyz/log.php?idcard=4E:66:C8:75HTTP/1.1 400 Bad Request
Date: Mon, 09 Mar 2020 14:32:49 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 150
Connection: close
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Referrer-Policy: no-referrer-when-downgrade
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
400 Bad Request
400 Bad Request
nginx
my code is:
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
WiFiClient client;
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN D4
#define RST_PIN D2
#define ERROR_PIN D0
#define SUCCESS_PIN D1
#define CONN_PIN D8
void baca_database();
MFRC522 rfid(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
String request_string;
const char* host = "belajar-hosting.xyz"; //
HTTPClient http;
WiFi.disconnect();
WiFi.begin("Sendaris","12345678ab");
while ((!(WiFi.status() == WL_CONNECTED))){
delay(300);
SPI.begin();
rfid.PCD_Init();
Serial.println("I am waiting for card...");
void toggleConnStat() {
if(WiFi.status() == WL_CONNECTED) {
digitalWrite(CONN_PIN, HIGH);
digitalWrite(CONN_PIN, LOW);
String strID,val, data;
while (client.available()>0){
delay(10);
char c = client.read();
data+=c;
if (data.length()>0){
Serial.println(data);
data="";
if (!rfid.PICC_IsNewCardPresent() || !rfid.PICC_ReadCardSerial())
return;
// Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
// Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
//id kartu dan yang akan dikirim ke database
strID = "";
for (byte i = 0; i < 4; i++) {
strID +=
(rfid.uid.uidByte < 0x10 ? "0" : "") +
String(rfid.uid.uidByte*, HEX) +*
(i != 3 ? ":" : "");
strID.toUpperCase();
Serial.print("Tap card key: ");
Serial.println(strID);
val = "500"; // nilai kartu yang akan dikirim
// tambah_database();
baca_database();
void tambah_database()
if (!client.connect(host,80)) {
Serial.println("Gagal Konek");
return;
request_string = "belajar-hosting.xyz/log.php?idcard=";
request_string += strID;
request_string += "&val=";
request_string += val;
Serial.print("requesting URL: ");
Serial.println(request_string);
client.print(String("GET ") + request_string + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: closernrn");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
return;
Serial.print(request_string);
client.print(String("GET ") + request_string + " HTTP/1.1rn" + "Host: " + host + "rn" + "Connection: closernrn");
client.stop();
return;
Please use code tags (the </> button) when posting code or long output logs - it makes it easier for people to read, and prevents the forum from mangling code (in particular, the forum sees indexing an array by a variable named i, as the start of an italic tag - but parens and punctuation can also get turned into smilies and such without code tags)...
That said, it looks like you're not URL-encoding the query string, that could be the issue. A colon is not a valid character in a URL - it needs to be URL encoded, and as far as I can tell, you're not doing that...
@fauzan12
Moved your topic to it's current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
