Sending data trough UDP
Hello to all,
I made a wifi connection between 2 esp8266. The program works perfectly for sending one byte (on/off). The problem arises when i try to send more value's.
The code gives on the receiving esp8266 the right value's, one byte and the floating value as a string through the serial monitor I tried creating a struct, which didn't work. Esp-now doesn't work either.
thanks in advance
The code for sending
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include<DHT.h>      // Including library for dht
// Set WiFi credentials
#define WIFI_SSID "TheOtherESP"
#define WIFI_PASS "flashmeifyoucan"
// UDP
WiFiUDP UDP;
IPAddress remote_IP(192, 168, 4, 1);
#define UDP_PORT 4210
#define dht_dpin 12       //digital pin, that DHT's data line is connected
#define DHTTYPE DHT22     //When using DHT11, put here DHT11 instead of DHT22
DHT dht(12, DHT22);       //Not sure, what this line excatly does, but same aplies here as above
float temp;
float hum;
  dht.begin();
  // Setup IO
  pinMode(2, INPUT);
  // Setup serial port
  // Begin WiFi
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  WiFi.mode(WIFI_STA);
  // Connecting to WiFi...
  Serial.print("Connecting to ");
  Serial.print(WIFI_SSID);
  // Loop continuously while WiFi is not connected
  while (WiFi.status() != WL_CONNECTED)
    delay(100);
    Serial.print(".");
  // Connected to WiFi
  Serial.print("Connected! IP address: ");
  // Begin UDP port
  UDP.begin(UDP_PORT);
  Serial.print("Opening UDP port ");
  Serial.println(UDP_PORT);
  temp = dht.readTemperature();
  hum = dht.readHumidity();
  // Read button
  char buttonState = digitalRead(2);
  // Send Packet
  UDP.beginPacket(remote_IP, UDP_PORT);
  UDP.write(buttonState);
   if (!UDP.endPacket()) {
    Serial.println("data has not been sent");
  } else
    Serial.println("data has been sent"); {
  String msg = String(hum);
  UDP.write(msg.c_str());
  } else
  Serial.print("Temperature: ");        //Print text "Temperature: " in to serial monitor
  Serial.println(temp);
  Serial.print("Humidity: ");           //Print text "Humidity: " in to serial monitor
  Serial.println(hum);                  //Print variable (temperature value) in to serial port. ln for line break
  Serial.println(" ");
The receiver code
// Set AP credentials
#define AP_SSID "TheOtherESP"
#define AP_PASS "flashmeifyoucan"
// UDP
WiFiUDP UDP;
IPAddress local_IP(192, 168, 4, 1);
IPAddress gateway(192, 168, 4, 1);
IPAddress subnet(255, 255, 255, 0);
float hum;
// UDP Buffer
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
char  ReplyBuffer[] = "acknowledged";
  // Setup LED pin
  pinMode(2, OUTPUT);
  // Begin Access Point
  Serial.println("Starting access point...");
  WiFi.softAPConfig(local_IP, gateway, subnet);
  WiFi.softAP(AP_SSID, AP_PASS);
  // Begin listening to UDP port
  Serial.print("Listening on UDP port ");
  // Receive packet
  int packetSize = UDP.parsePacket();
  if (packetSize) {
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remoteIp = UDP.remoteIP();
    Serial.print(remoteIp);
    Serial.print(", port ");
    Serial.println(UDP.remotePort());
    // read the packet into packetBufffer
    int len = UDP.read(packetBuffer, 10);
    if (len > 0) {
      packetBuffer[len] = 0;
    if (packetBuffer[0]) {
      digitalWrite(2, HIGH);
      digitalWrite(2, LOW);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
You are sending two types of the packets - first with one byte and second with string. But try to read both as first type only. Obviously it won't work this way.
please show your efforts
Here's the code (sent/receive) with the struct in it. The led still toggle's through UDP, so it means that the byte's get trough otherwise it wouldn't turn on the onboard LED on pin 2.
// UDP
WiFiUDP UDP;
float temp;
float hum;
typedef struct settings_t{
  byte button;
  float temp;
  float hum;
const int union_size = sizeof(settings_t);
typedef union btPacket_t{
 settings_t structure;
 byte byteArray[union_size];
//create a variable using this new union we defined
btPacket_t settings;
  dht.begin();
  // Setup IO
  pinMode(2, INPUT);
  // Begin WiFi
    delay(100);
    Serial.print(".");
  // Begin UDP port
  settings.structure.button = digitalRead(2);
  settings.structure.hum = dht.readTemperature();
  settings.structure.temp = dht.readTemperature();
  // Send Packet
  for(int i=0; i < union_size; i++)
  UDP.write(settings.byteArray[i]);
  } else
Here's the receive
// UDP
WiFiUDP UDP;
byte button;
float temp;
float hum;
typedef struct settings_t {
  byte button;
  float temp;
  float hum;
typedef union btPacket_t {
// UDP Buffer
  // Setup LED pin
  pinMode(2, OUTPUT);
  // Receive packet
  if (packetSize) {
    int len = UDP.read(packetBuffer, 255);
    if (len > 0) {
    if (Serial.available()) {
      Serial.println(button);
    else {
      Serial.println(0);
      Serial.println(0);
      Serial.println(0);
    Serial.flush();
   if (button) {
