I am attempting to send data wirelessly to my laptop using Arduino MKR WiFi 1010. My Arduino is getting connected to the network but how do I send the temperature readings to the serial monitor wirelessly? Everytime I disconnect the USB, the connection to the serial monitor dies (it makes sense). I want to save the data as an excel file - any suggestions on how to do that? Below is my code. Would appreciate the help greatly!
MKR1000 - MKR WiFi 1010 - MKR VIDOR 4000 WiFi RTC
This sketch asks NTP for the Linux epoch and sets the internal Arduino MKR1000's RTC accordingly.
created 08 Jan 2016
by Arturo Guadalupi <a.guadalupi@arduino.cc>
modified 26 Sept 2018
http://arduino.cchttps://www.arduino.cc/en/Tutorial/WiFiRTC
This code is in the public domain.
#include <SPI.h>
#include <WiFiNINA.h> //Include this instead of WiFi101.h as needed
#include <WiFiUdp.h>
#include <RTCZero.h>
float temperature = 0;
int tempPin = 0;
RTCZero rtc;
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
//int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
const int GMT = 8; //change this to adapt it to your time zone
// check if the WiFi module works
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// init the CSV file with headers
Serial.println("temperature");
// you're connected now, so print out the status:
printWiFiStatus();
rtc.begin();
unsigned long epoch;
int numberOfTries = 0, maxTries = 6;
do {
epoch = WiFi.getTime();
numberOfTries++;
while ((epoch == 0) && (numberOfTries < maxTries));
if (numberOfTries == maxTries) {
Serial.print("NTP unreachable!!");
while (1);
else {
Serial.print("Epoch received: ");
Serial.println(epoch);
rtc.setEpoch(epoch);
temperature = analogRead(tempPin);
Serial.print(temperature);
printDate();
printTime();
void printTime()
print2digits(rtc.getHours() + GMT);
Serial.print(":");
print2digits(rtc.getMinutes());
Serial.print(":");
print2digits(rtc.getSeconds());
void printDate()
Serial.print(rtc.getDay());
Serial.print("/");
Serial.print(rtc.getMonth());
Serial.print("/");
Serial.print(rtc.getYear());
Serial.print(" ");
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void print2digits(int number) {
if (number < 10) {
Serial.print("0");
Serial.print(number);
