Sending email notifications failed
Hello i found sketch online that would let me send an alarm to my email I’m adapting a ESP8266 to my alarm system the system i have doesn’t have a internet connection or gsm connection. I found this sketch i filled out the correct information and I’m getting a error stating SMTP responded that it could not connect to the mail server. Can someone please help me? Below is the sketch. I did everything it told me to do i got no errors in compiling and uploading it just won’t send it.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <base64.h>
const int     SMTP_PORT            = 465;
const char*   SMTP_SERVER          = "smtp.gmail.com";
String        error_message;
String        ServerResponse;
const char*   ssid     = "your_wifi_ssid";                       // WIFI network name
const char*   password = "your_wifi_password";                   // WIFI network password
String Senders_Login    = "your_email_user_account@gdomain.com";
String Senders_Password = "your_email_account_password";
String From;
String To, Subject, Message, Login_base64, Passwrd_base64;
WiFiClientSecure client;
  WiFi.begin(ssid, password);
  Serial.print("Connecting to :"+String(ssid));
  To      = "recipients_email_address@domain.com";
  From    = "your_email_address@domain.com";
  Subject = "Test Message";
  Message = "This is a test message to demonstrate how to send an email from and ESP8266";
  SendMail(To, Subject, Message);
  if (error_message != "") Serial.println(error_message);
  delay(10000000);
void SendMail(String To, String Subject, String Message) {
  if (!client.connect(SMTP_SERVER, SMTP_PORT)) {
    error_message = "SMTP responded that it could not connect to the mail server";
    return;
  if (ErrorWhileWaitingForSMTP_Response("220", 500)) {
    error_message = "SMTP responded with a Connection Error";
    return;
  client.println("HELO server");
  if (ErrorWhileWaitingForSMTP_Response("250", 500)) {
    error_message = "SMTP responded with an Identification error";
    return;
  client.println("AUTH LOGIN");
  WaitSMTPResponse(ServerResponse, 500);
  client.println(base64::encode(Senders_Login));
  client.println(base64::encode(Senders_Password));;
  if (ErrorWhileWaitingForSMTP_Response("235", 500)) {
    error_message = "SMTP responded with an Authorisation error";
    return;
  String mailFrom = "MAIL FROM: <" + String(From) + '>';
  client.println(mailFrom);
  String recipient = "RCPT TO: <" + To + '>';
  client.println(recipient);
  client.println("DATA");
  if (ErrorWhileWaitingForSMTP_Response("354", 500)) {
    error_message = "SMTP DATA error";
    return;
  client.println("From: <" + String(From) + '>');
  client.println("To: <" + String(To) + '>');
  client.print("Subject: ");
  client.println(String(Subject));
  client.println("Mime-Version: 1.0");
  client.println("Content-Type: text/html; charset=\"UTF-8\"");
  client.println("Content-Transfer-Encoding: 7bit");
  client.println();
  String body = "<!DOCTYPE html><html lang=\"en\">" + Message + "</html>";
  client.println(body);
  client.println(".");
  if (ErrorWhileWaitingForSMTP_Response("250", 1000)) {
    error_message = "SMTP responded with a Message error";
    return;
  client.println("QUIT");
  if (ErrorWhileWaitingForSMTP_Response("221", 1000)) {
    error_message = "SMTP responded with a QUIT error";
    return;
  client.stop();
  Serial.println("Message Sent");
bool ErrorWhileWaitingForSMTP_Response(String Error_Code, int TimeOut) {
  int timer = millis();
  while (!client.available()) {
    if (millis() > (timer + TimeOut)) {
      error_message = "SMTP responsed that a Timeout occurred";
      return true;
  ServerResponse = client.readStringUntil('\n');
  if (ServerResponse.indexOf(Error_Code) == -1) return true;
  return false;
bool WaitSMTPResponse(String Error_Code, int TimeOut) {
      error_message = "SMTP responded that a Timeout occurred";
      return false;
  if (ServerResponse.indexOf(Error_Code) == -1) return false;
  return true;
I found this sketch i filled out the correct information and I'm getting a error stating SMTP responded that it could not connect to the mail server.
Did you check that your ESP has full internet connectivity? The error message usually means the connection was blocked somehow. Might even be your provider blocking connections to port 465.
Hello maybe. I have Comcast business. They say on business that ports are not blocked. But maybe they are.
Connect a PC and try to open port 465. What result do you get?
port 465 won't go through.
josephchrzempiec:
So the problem is not in the ESP but in your network setup. Check provider, firewall, NAT and whatever else you have inbetween you and the actual Internet.
