Hello Everyone ,
I am doing project with ESP8266 and arduino Uno. My project is Sending Email using Arduino and ESP8266 WiFi Module.
My WiFi module got connected to my wifi. But it is not showing correct output. The error I am getting is
the following
IPSEND=4,34
busy s…
Recv 18 bytes
SEND OK
+IPD,4,35:535 Incorrect authentication data
MAIL FROM:pavamanakj@gmail.com
ERROR
AT+CIPSEND=4,32
OK
T+CIPSEND=4,6
busy s…
Recv 32 bytes
SEND OK
+IPD,4,26:500 unrecognized command
AT+CIPSEND=4,24
OK
END=4,3
busy s…
Recv 24 bytes
SEND OK
AT+CIPSEND=4,6
OK
Recv 6 bytes
SEND OK
+IPD,4,26:500 unrecognized command"
Pls someone help me to fix this error. When I checked AT commands tests, WiFi module responds correctly.
The code for the project is the following
#include<LiquidCrystal.h>
LiquidCrystal lcd(14,15,16,17,18,19);
#include <SoftwareSerial.h>
SoftwareSerial Serial1(2, 3); // RX, TX
boolean No_IP=false;
String IP="";
void check4IP(int t1)
int t2=millis();
Serial1.flush();
while(t2+t1>millis())
while(Serial1.available()>0)
if(Serial1.find("WIFI GOT IP"))
No_IP=true;
void get_ip()
IP="";
char ch=0;
while(1)
Serial1.println("AT+CIFSR");
if(Serial1.find("STAIP,"))
Serial.print("IP Address:");
ch=Serial1.read();
if(ch=='+')
IP+=ch;
if(ch=='+')
if(ch=='+')
Serial.print(IP);
Serial.print("Port:");
Serial.println(80);
void connect_wifi(String cmd, int t)
int temp=0,i=0;
while(1)
Serial1.println(cmd);
while(Serial1.available())
if(Serial1.find("OK"))
i=8;
delay(t);
if(i>5)
i++;
if(i==8)
Serial.println("OK");
Serial.println("Error");
Serial1.begin(9600);
// Serial.begin(9600);
lcd.begin(16,2);
lcd.print("Sending Email by");
lcd.setCursor(0,1);
lcd.print(" Arduino & WIFI ");
delay(2000);
lcd.clear();
lcd.print(" Circuit Digest ");
delay(2000);
lcd.clear();
lcd.print("Finding ESP8266");
connect_wifi("AT",100);
connect_wifi("ATE1",100);
lcd.clear();
lcd.print("Connected");
connect_wifi("AT+CWMODE=3",100);
connect_wifi("AT+CWQAP",100);
connect_wifi("AT+RST",5000);
lcd.clear();
lcd.print("Connecting WiFi");
check4IP(5000);
if(!No_IP)
Serial.println("Connecting Wifi....");
connect_wifi("AT+CWJAP=\"1st floor\",\"muda1884\"",7000); //provide your WiFi username and password here
lcd.clear();
lcd.print("WIFI Connected...");
Serial.println("Wifi Connected");
lcd.clear();
lcd.print("Getting IP Add.");
Serial.println("Getting IP Address....");
get_ip();
lcd.clear();
lcd.print("IP:");
lcd.print(IP);
lcd.setCursor(0,1);
lcd.print("PORT: 80");
connect_wifi("AT+CIPMUX=1",100);
connect_wifi("AT+CIPSERVER=1,80",100);
delay(2000);
lcd.clear();
lcd.print("Configuring Email..");
Serial1.println("AT+CIPSTART=4,\"TCP\",\"mail.smtp2go.com\",2525");
delay(2000);
Serial1.println("AT+CIPSEND=4,20");
delay(2000);
Serial1.println("EHLO 192.168.1.123");
delay(2000);
Serial1.println("AT+CIPSEND=4,12");
delay(2000);
lcd.clear();
lcd.print("Try To Login.....");
Serial1.println("AUTH LOGIN");
delay(2000);
Serial1.println("AT+CIPSEND=4,30");
delay(2000);
Serial1.println("c2FkZGFtNDIwMUBnbWFpbC5jb20="); //base64 encoded username
delay(2000);
Serial1.println("AT+CIPSEND=4,18");
delay(2000);
Serial1.println("Y2lyY3VpdDQyMDE="); //base64 encoded password
lcd.clear();
lcd.print("Login Success");
delay(2000);
Serial1.println("AT+CIPSEND=4,34");
delay(2000);
Serial1.println("MAIL FROM:<saddam4201@ gmail.com>"); // use your email address
delay(2000);
Serial1.println("AT+CIPSEND=4,32");
delay(2000);
lcd.clear();
lcd.print("Seniding Email 2");
lcd.setCursor(0,1);
lcd.print("Saddam4201@ gmail");
Serial1.println("RCPT To:<saddam4201@ gmail.com>");
delay(2000);
Serial1.println("AT+CIPSEND=4,6");
delay(2000);
Serial1.println("DATA");
delay(2000);
Serial1.println("AT+CIPSEND=4,24");
delay(2000);
Serial1.println("Testing Success");
delay(2000);
Serial1.println("AT+CIPSEND=4,3");
delay(2000);
Serial1.println('.');
delay(10000);
delay(2000);
Serial1.println("QUIT");
delay(2000);
lcd.clear();
lcd.print("Email Sent...");
