Hi, guys I have a problem that I seeked answers for a couple of weeks and could not find some some concrete answers except one but did not work for me.
Here's what I want to do:
- Capture an image from and ArduCAM (done)
- Save it to SD Card(done)
- Send the image taken to the database via Wifi with the Wifi Shield CC3000
- Receive the data and save it to a temporary folder thru PHP
I have found this thread on the forums and tried it but failed.
http://forum.arduino.cc/index.php?topic=348012.0
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include<stdlib.h>
#include <SD.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// WiFi network (change with your settings !)
#define WLAN_SSID "mywirelessnetwork"
#define WLAN_PASS "mypassword"
#define WLAN_SECURITY WLAN_SEC_WPA2
// Create CC3000 instances
// WIFi setup
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,SPI_CLOCK_DIV2);
Adafruit_CC3000_Client client;
char filename[14] = "CAM1.jpg";
int i = 0;
int keyIndex = 1;
int port = 80; //Server Port
uint32_t MANip = 0;
// Initialise the module
Serial.println(F("\nInitializing..."));
if (!cc3000.begin()){
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
// Connect to WiFi network
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println(F("Connected!"));
// Display connection details
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP()){
delay(100);
Serial.println("Ready");
Serial.println("-------");
//Get MAN IP address
getMANip();
// Prepare HTTP request
String start_request = "";
String end_request = "";
start_request = start_request + "\n" + "--AaB03x" + "\n" + "Content-Disposition: form-data; name=\"fileToUpload\"; filename="+filename+"\n" + "Content-Type: file" + "\n" + "Content-Transfer-Encoding: binary" + "\n" + "\n";
end_request = end_request + "\n" + "--AaB03x--" + "\n";
//Initialise SD Card
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization of SD done.");
File myFile = SD.open("CAM1.jpg");
uint16_t jpglen = myFile.size();
uint16_t extra_length;
extra_length = start_request.length() + end_request.length();
uint16_t len = jpglen + extra_length;
// Set up TCP connection with web server
client = cc3000.connectTCP(MANip, port);
if (client.connected()) {
Serial.println("Start uploading...");
client.println(F("POST /~modelavi/plugins/upload.php HTTP/1.1"));
client.println(F("Host: www.modelaviationnorthland.co.nz"));
client.println(F("Content-Type: multipart/form-data; boundary=AaB03x"));
client.print(F("Content-Length: "));
client.println(len);
client.println(start_request);
Serial.println(F("Host: www.modelaviationnorthland.co.nz"));
Serial.println(F("Content-Type: multipart/form-data; boundary=AaB03x"));
Serial.print(F("Content-Length: "));
Serial.println(len);
Serial.println(start_request);
if (myFile) {
byte clientBuf[32];
int clientCount = 0;
while(myFile.available())
clientBuf[clientCount] = myFile.read();
clientCount++;
if(clientCount > 31)
client.write(clientBuf,32);
clientCount = 0;
if(clientCount > 0) client.write(clientBuf,clientCount);
client.print(end_request);
client.println();
else{
Serial.println("File not found");
else{
Serial.println("Web server connection failed");
myFile.close();
client.close();
Serial.println("done...");
delay(10000);
void getMANip(){
#ifndef CC3000_TINY_DRIVER
/* Try looking up www.modelaviationnorthland.co.nz */
//Serial.print(F("www.modelaviationnorthland.co.nz -> "));
while (MANip == 0) {
if (! cc3000.getHostByName("www.modelaviationnorthland.co.nz", &MANip)) {
//Serial.println(F("Couldn't resolve!"));
//cc3000.printIPdotsRev(MANip);
#endif
Here's the code but I got stuck on "Start uploading..." as I check on the Serial monitor.
- Anybody has a solution on this?
- Or anybody has some other way to send the image taken to the server?
