HI here is the code i am using
String myAPIkey = "HPETZAC65TF1NP4B";
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int temp_f;
long writingTimer = 17;
long startTime = 0;
long waitTime = 0;
boolean relay1_st = false;
boolean relay2_st = false;
unsigned char check_connection=0;
unsigned char times_check=0;
boolean error;
SoftwareSerial ESP8266(4, 5);
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
mySerial.begin(9600);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
inifinger();
wifi();
void akash(void) // run over and over again
int ad=1;
while(ad==1){
int a=getFingerprintIDez();
if (a>0)
ad=0;
//mySerial.end();
void inifinger()
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
Serial.println("Waiting for valid finger...");
akash();
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
temp_f=finger.fingerID;
Serial.print(temp_f);
void wifi(){
ESP8266.begin(9600);
// dht.begin();
startTime = millis();
ESP8266.println("AT+RST");
delay(2000);
Serial.println("Connecting to Wifi");
while(check_connection==0)
Serial.print(".");
ESP8266.print("AT+CWJAP=\"akash\",\"12345678\"\r\n");
ESP8266.setTimeout(5000);
if(ESP8266.find("WIFI CONNECTED\r\n")==1)
Serial.println("WIFI CONNECTED");
times_check++;
if(times_check>3)
times_check=0;
Serial.println("Trying to Reconnect..");
void writeThingSpeak(void)
startThingSpeakCmd();
// preparacao da string GET
String getStr = "GET /update?api_key=";
getStr += myAPIkey;
getStr +="&field1=";
getStr += String(temp_f++);
//getStr +="&field2=";
//getStr += String(humidity);
getStr += "\r\n\r\n";
GetThingspeakcmd(getStr);
void startThingSpeakCmd(void)
ESP8266.flush();
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += "184.106.153.149"; // api.thingspeak.com IP address
cmd += "\",80";
ESP8266.println(cmd);
Serial.print("Start Commands: ");
Serial.println(cmd);
if(ESP8266.find("Error"))
Serial.println("AT+CIPSTART error");
return;
String GetThingspeakcmd(String getStr)
String cmd = "AT+CIPSEND=";
cmd += String(getStr.length());
if(ESP8266.find(">"))
ESP8266.print(getStr);
Serial.println(getStr);
String messageBody = "";
while (ESP8266.available())
String line = ESP8266.readStringUntil('\n');
if (line.length() == 1)
messageBody = ESP8266.readStringUntil('\n');
Serial.print("MessageBody received: ");
Serial.println(messageBody);
return messageBody;
ESP8266.println("AT+CIPCLOSE");
Serial.println("AT+CIPCLOSE");
prathu1998:
int temp_f;
long startTime = 0;
long waitTime = 0;
boolean error;
delay(100);
inifinger();
wifi();
int ad=1;
while(ad==1){
if (a>0)
ad=0;
//mySerial.end();
void inifinger()
akash();
switch (p) {
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
return p;
return p;
return p;
// found a match!
// found a match!
void wifi(){
// dht.begin();
delay(2000);
Serial.print(".");
ESP8266.print("AT+CWJAP="akash","12345678"\r\n");
times_check++;
if(times_check>3)
times_check=0;
getStr += myAPIkey;
ESP8266.flush();
String cmd = "AT+CIPSTART="TCP","";
cmd += "",80";
return;
return messageBody;
and this is not sending the data to my channel can anyone help me please?
