Sending floats from an arduino to another arduino over SPI using a union
Im trying to send floats from one arduino to another over SPI using a union. I know my wiring is correct because I can send integers. The code looks correct to me so I must be missing something. When I run the code the serial monitor just prints out 0.0000.
Here is my master code
#include <SPI.h>
#include "pins_arduino.h"
void setup ()
  Serial.begin (115200);
  digitalWrite(SS, HIGH);  // ensure SS stays high for now
  // Put SCK, MOSI, SS pins into output mode
  // also put SCK, MOSI into LOW state, and SS into HIGH state.
  // Then put SPI hardware into Master mode and turn SPI on
  SPI.begin ();
  // Slow down the master a bit
  SPI.setClockDivider(SPI_CLOCK_DIV8);
byte transferAndWait (const byte what)
  byte a = SPI.transfer (what);
  delayMicroseconds (10);
  return a;
union first_union
  float f;
  byte b[4];
}data;
float yaw, pitch, roll, alt, temp;
void loop (void)
  digitalWrite(SS, LOW);
  //YAW
  transferAndWait ('Y');
  data.b[0] = transferAndWait ('1');
  data.b[1] = transferAndWait ('2');
  data.b[2] = transferAndWait ('3');
  data.b[3] = transferAndWait ('Z');
  yaw = data.f;
  //PITCH
  transferAndWait ('P');
  pitch = data.f;
  //ROLL
  transferAndWait ('R');
  roll = data.f;
  //TEMP
  transferAndWait ('T');
  temp = data.f;
  //ALT
  transferAndWait ('A');
  alt = data.f;
  Serial.print("yaw:");
  Serial.println(yaw, 4);
  Serial.print("pitch: ");
  Serial.println(pitch,4);
  Serial.print("roll:");
  Serial.println(roll,4);
  Serial.print("alt: ");
  Serial.println(alt,4);
  Serial.print("temp: ");
  Serial.println(temp,4);
  delay(100);
and my slave code
#include <EEPROM.h>
#include <FreeIMU.h>
#include <Wire.h>
#include <SPI.h>
#include <HMC58X3.h>
#include <MS561101BA.h>
#include <I2Cdev.h>
#include <MPU60X0.h>
//Set the default object
FreeIMU my3IMU = FreeIMU();
float ypr[3];
float alt = 0;
float temp = 0;
  //Setup IMU
  Wire.begin();
  my3IMU.init(true);
  // have to send on master in, *slave out*
  pinMode(MISO, OUTPUT);
  // turn on SPI in slave mode
  SPCR |= _BV(SPE);
  // turn on interrupts
  SPCR |= _BV(SPIE);
union first_union
    float f;
    byte b[4];
}data;
ISR (SPI_STC_vect)
  byte command = SPDR;
  switch (command)
  case 'Z':
    data.f = 0;
    SPDR = 0;
  case 'Y':
    data.f = ypr[0];
    SPDR = data.b[0];
  case 'P':
    data.f = ypr[2];
    SPDR = data.b[0];
  case 'R':
    data.f = ypr[1];
    SPDR = data.b[0];
  case 'A':
    data.f = alt;
    SPDR = data.b[0];
  case 'T':
    data.f = temp;
    SPDR = data.b[0];
  case 1:
    SPDR = data.b[1];
  case 2:
    SPDR = data.b[2];
  case 3:
    SPDR = data.b[3];
  //my3IMU.getYawPitchRoll(ypr);
  //alt = my3IMU.getBaroAlt();
  //temp = my3IMU.getBaroTemp();
  ypr[0] = 1.1111;
  ypr[1] = 2.2222;
  ypr[3] = 3.3333;
  alt = 4.4444;
  temp = 5.5555;
Any ideas?
Thanks
Solved, by adding apostrophes around my numbers in my switch case so that i’m switching on a char rather than a number.
Cheers
Dear joe4465 can you upload your final correction, please.
