I want to dial out on a phone.
Lift the handset, then send the tones to dial.
Then, connect to a remove fax machine.
Then, send data to that machine so that it will be printed.
I have a remote cabin that has a phone line. I may be able to use one of the neighbors wi-fi as a guest if there is a way to search for an available link, then send an e-mail on that ?? I do not think I could get a password for access.
I also want a million dollars.
Anyone know how I can make either of these happen ?
dave-in-nj:
Presumably you want this to be done automatically rather than manually. The easiest way to do that is to get a PC or laptop with fax/modem capabilities.
I found a couple low cost devices that will dial a phone. since one has to have a license device to tie into a phone system, this can do that interface.
Quote "second is about tapping into any available wi-fi without prior having to set up passwords and such ?"
quote reply : " Nope. Not going there."
I do not want to do anything illegal. many wi-fi units have provisions for either guest or are just open. a wi-fi hotspot.
I thought there may be a way to see a connection, test it to see if it needs a password, then if it does, try a different one until an open connection is found.
