Sending gas sensor readings through Lora
Hi! I'm currently trying to read gas sensor readings from a MQ2 gas sensor that is mounted on a RAK 4631 and then send the signals to a Lora32 T-beam. I'm just wondering would it work since the RAK 4631 and Lora32 are using 2 different libraries.
For the RAK, I'm using the sx126x-Arduino library and for the T-beam, I am planning to use the Lora Library by sandeepmistry. I believe I am almost done with the code for the transmitter and I'm wondering if I'm on the right track. Thank you so much for any input.
#include <Adafruit_TinyUSB.h>
#include <SX126x-RAK4630.h>
#include <SPI.h>
#include <Wire.h>
#include "ADC121C021.h"
#include <U8g2lib.h>       // Click to install library: http://librarymanager/All#u8g2
//defining the functions for reading the gas sensor values
#define EN_PIN WB_IO6	 //Logic high enables the device. Logic low disables the device
#define ALERT_PIN WB_IO5 //a high indicates that the respective limit has been violated.
#define MQ2_ADDRESS 0x51 //the device i2c address
#define RatioMQ2CleanAir (1.0) //RS / R0 = 1.0 ppm
#define MQ2_RL (10.0)		   //the board RL = 10KΩ  can adjust
//defining the parameters for the lora peer to peer communication
// Define LoRa parameters
#define RF_FREQUENCY 923000000 // Hz
#define TX_OUTPUT_POWER 22		// dBm
#define LORA_BANDWIDTH 0		// [0: 125 kHz, 1: 250 kHz, 2: 500 kHz, 3: Reserved]
#define LORA_SPREADING_FACTOR 7 // [SF7..SF12]
#define LORA_CODINGRATE 1		// [1: 4/5, 2: 4/6,  3: 4/7,  4: 4/8]
#define LORA_PREAMBLE_LENGTH 8  // Same for Tx and Rx
#define LORA_SYMBOL_TIMEOUT 0   // Symbols
#define LORA_FIX_LENGTH_PAYLOAD_ON false
#define LORA_IQ_INVERSION_ON false
#define RX_TIMEOUT_VALUE 5000 //changed from original value of 3000
#define TX_TIMEOUT_VALUE 5000 //changed from original value of 3000
//Lora function declarations
void OnTxDone(void);
void OnTxTimeout(void);
#ifdef NRF52_SERIES
#define LED_BUILTIN 35
#endif
//for mq2 sensor
ADC121C021 MQ2;
uint16_t result;
//for lorawan sensor
static RadioEvents_t RadioEvents;
static uint8_t TxdBuffer[64];
  //mq2 sensor start
	pinMode(ALERT_PIN, INPUT);
	pinMode(EN_PIN, OUTPUT);
	digitalWrite(EN_PIN, HIGH); //power on RAK12004
	delay(5);
  //initialize the lora chip
  lora_rak4630_init();
	time_t timeout = millis();
	while (!Serial)
		delay(100); //delaying for 100 milliseconds indefinitely
	//********ADC121C021 ADC convert init ********************************
	while (!(MQ2.begin(MQ2_ADDRESS, Wire)))
		Serial.println("please check device!!!");
		delay(200);
	Serial.println("MQ2 gas sensor seems to be working fine");
  //testing the lora p2p test
  Serial.println("============");
  Serial.println("Lorap2p Tx Test");
  Serial.println("=========");
  //Initialize radio call backs
  RadioEvents.TxDone = OnTxDone;
  RadioEvents.RxDone = NULL; //since this is for transmission
  RadioEvents.TxTimeout = OnTxTimeout;
  RadioEvents.RxTimeout = NULL;
  RadioEvents.RxError = NULL;
  //Initialize the radio
  Radio.Init(&RadioEvents);
  //Set the radio channel
  Radio.SetChannel(RF_FREQUENCY);
  //Set Radio Tx configuration
  Radio.SetTxConfig(MODEM_LORA, TX_OUTPUT_POWER, 0 , LORA_BANDWIDTH, LORA_SPREADING_FACTOR, LORA_CODINGRATE, LORA_PREAMBLE_LENGTH, LORA_FIX_LENGTH_PAYLOAD_ON, true, 0, 0, LORA_IQ_INVERSION_ON, TX_TIMEOUT_VALUE);
  send();
  delay(3000);
  //sending some data to establish connection
	//**************init MQ2 *****************************************************
	MQ2.setRL(MQ2_RL);
   *detect Propane gas if to detect other gas  need to reset A and B value,it depend on MQ sensor datasheet
	MQ2.setA(-0.890);			//A -> Slope, -0.685
	MQ2.setB(1.125);			//B -> Intersect with X - Axis  1.019
								//Set math model to calculate the PPM concentration and the value of constants
	MQ2.setRegressionMethod(0); //PPM =  pow(10, (log10(ratio)-B)/A)
	float calcR0 = 0;
	for (int i = 1; i <= 100; i++)
		calcR0 += MQ2.calibrateR0(RatioMQ2CleanAir);
	MQ2.setR0(calcR0 / 10);
	if (isinf(calcR0))
		Serial.println("Warning: Conection issue founded, R0 is infite (Open circuit detected) please check your wiring and supply");
		while (1)
	if (calcR0 == 0)
		Serial.println("Warning: Conection issue founded, R0 is zero (Analog pin with short circuit to ground) please check your wiring and supply");
		while (1)
	float r0 = MQ2.getR0();
	Serial.printf("R0 Value is:%3.2f\r\n", r0);
	float sensorPPM;
	float PPMpercentage;
  //handle radio events
  Radio.IrqProcess();
	Serial.println("Getting Conversion Readings from ADC121C021");
	Serial.println(" ");
	sensorPPM = MQ2.readSensor();
	Serial.printf("sensor PPM Value is: %3.2f\r\n", sensorPPM);
	PPMpercentage = sensorPPM / 10000;
  sensorPPM = round(sensorPPM*100)/100;
  Serial.printf ("The new rounded value of sensorPPM is ", sensorPPM); //to test the value of the new rounded file
	Serial.printf("PPM percentage Value is:%3.2f%%\r\n", PPMpercentage);
	Serial.println("        ***************************        ");
  int intPart = (int)sensorPPM;
  float decPart = sensorPPM - (float)intPart;
  if (sensorPPM >= 1000 ){
    int temp = intPart;
    uint8_t ppmbuf[7];
    for (int i=3 ; i >=0  ; i--){
      ppmbuf[i] = temp % 10;
      temp /= 10;
    ppmbuf[4] = -1;
    ppmbuf[5] =  (int)(decPart *100) % 10 ;
    ppmbuf[6] =  (int)(decPart *100) / 10;
    Radio.Send(ppmbuf, 7);
  else {
    uint8_t ppmbuf[6];
    int temp = intPart;
    for (int i=2 ; i >= 0 ; i--){
      temp = temp / 10;
    ppmbuf[3] = -1;
    ppmbuf[4] = (int)(decPart *100) % 10;
    ppmbuf[5] = (int)(decPart *100) / 10;
    Radio.Send(ppmbuf, 6);
	delay(5000);
  yield();
void OnTxDone(void){
  Serial.println("onTxDone");
  delay(5000);
  send();
  Serial.println("OnTxTimeout");
void send(){
  TxdBuffer[0] = 'H';
  TxdBuffer[1] = 'e';
  TxdBuffer[2] = 'l';
  TxdBuffer[3] = 'l';
  TxdBuffer[4] = 'o';
  Radio.Send(TxdBuffer, 5);
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming Questions category of the forum
An SX126x can communicate with an SX127x.
However you do need to be sure all the LoRa parameters match, do not assume the defaults used by one library are the same as the defaults used by another library.
Much easier to start with basic send and receive examples.
in theory communication should be possible
having different host microcontrollers, LoRa modules and libraries generates problems
for a start make sure the LoRa parameters of transmitter and receiver are identical
Thank you to both @srnet and @horace for the advice. I will keep that in mind. I will make sure that all the parameters are the same. However, I do still have a doubt. There is no place for me to enter a unique device id or something similar.
In lora p2p communication, how does the sender know that the packet will be received by the designated receiver and not another device that is operating in the same band?
Thanks!
If the LoRa settings are the same, all receivers in range will receive the packet.
Its up to your software to read the packets contents and work out as to whether a particular receiver accepts and processes that packet.
And unless you have a send and acknnowledge setup you will not know if the receiver the packet is intended for has actually received and acted upon it.
Hi
I have used info from Stuart with success for my lora
