Sending images over NFC to be displayed on e-paper
Hello, first of of all I want to apologize if this is not the right place for this question as it's not techically about arduino's but after asking this questions on a few places I got recommended this forum. So basically I am trying to communicate with an NFC module connected to an e-paper display and want to send the images to be displayed there. I got the commands from the manufacturer but every time I try to use them or do something I get TagLostException (this is in kotlin/java). This exception happens because the command is not right.
var data_DB = "F0DB000069";//10    βÊýÊǺóÃæËùÓÐÊý¾ÝºÍµÄÒ»°ë¡£
var start = "A00603300190012C";//16   4.2´çµ¥É«400x300
var RST = "A4010C" + "A502000A" + "A40108" + "A502000A" + "A4010C" + "A502000A" + "A40108" + "A502000A" + "A4010C" + "A502000A" + "A40108" + "A502000A" + "A4010C" + "A502000A" + "A40103"; // 48 +56   ¸´Î»Èý´Î
var set_wf = "A102000F";//8  //0x00 0F
var set_power = "A10104" + "A40103";//12  //0x04  busy
var set_resolution = "A105610190012C";//14   //0x61 01 90 01 2C
var set_border = "A1025097";//8  //0x50 97
var write_BW = "A3021013"; //6    //0x10
var write_BWR = "A3021013"; //8   //0x13
var update = "A20112" + "A502000A" + "A40103";//20  //0x12 delay  busy
var sleep = "A20102" + "A40103" + "A20207A5"; //20 //0x02 busy 07 A5
val epd_init: Array<String> = arrayOf(
    data_DB + start + RST + set_wf + set_resolution + set_border + set_power + write_BWR + update + sleep, //16+104+8+12+14+8+8+20+20=152   210/2=0x69 //ÇÐÆÁ
    "F0DA000003F00330" //10    ÆÁÄ»²ÎÊý0000  Êý¾Ý³¤¶È03   ×Ô¶¨ÒåÆÁÄ»F0    ÆÁÄ»³ß´ç·Ö±æÂÊ12   ÆÁÄ»ÑÕÉ«20   £¨ÆÁÄ»·Ö±æÂʺÍÑÕÉ«ºÍA0ÃüÁîÒ»Ö£©
override fun onNewIntent(intent: Intent?) {
    super.onNewIntent(intent)
    val p: Parcelable = intent?.getParcelableExtra(NfcAdapter.EXTRA_TAG) ?: return
    val tag = p as Tag
    val nfcA = NfcA.get(tag)
    if(nfcA != null) {
        try {
            Log.e("debug", "intent")
            nfcA.connect()
            var cmd: ByteArray
            var response: ByteArray
            nfcA.timeout = 60000
            cmd = hexStringToBytes(epd_init[0])
            response = nfcA.transceive(cmd)
            Log.e("epdinit_state", HexToString(response))
            cmd = hexStringToBytes(epd_init[1])
            //image_buffer is set to half white half black 400x300 image
            val datas = width0 * height0 / 8
            for (i in 0 until datas / 250) {
                cmd = byteArrayOf(0xF0.toByte(), 0xD2.toByte(), 0x00, i.toByte(), 0xFA.toByte())
                for (j in 0 until 250) {
                    cmd[j + 5] = image_buffer[j + 250 * i]
                response = nfcA.transceive(cmd) // Send black and white data
                Log.e("${i + 1} sendData_state:", HexToString(response)) // Feedback data display, 9000 is Ok
                // Data mantissa sending
                if (i == datas / 250 - 1 && datas % 250 != 0) {
                    cmd = byteArrayOf(0xF0.toByte(), 0xD2.toByte(), 0x00, (i + 1).toByte(), 0xFA.toByte())
                        cmd[j + 5] = image_buffer[j + 250 * (datas / 250)]
            val refreshCmd = byteArrayOf(0xF0.toByte(), 0xD4.toByte(), 0x05, 0x80.toByte(), 0x00)
            response = nfcA.transceive(refreshCmd) // Send e-paper refresh command
            Log.e("RefreshData1_state:", HexToString(response)) // Feedback data display, 9000 is Ok
            if (response[0] != 0x90.toByte()) {
                response = nfcA.transceive(refreshCmd) // Send black and white refresh command
                Log.e("RefreshData2_state:", HexToString(response))
        } catch (e: Exception) {
            e.printStackTrace()
            Log.e("debug", "Exception in onNewIntent: $e")
        } finally {
            nfcA.close()
These are the commands and code I am using to get it to work. I looked into the user manuals both for the display and the module and the commands seem to be correct but this is my first time doing something like this and I could be wrong. If any of you have any experience with this or sending data via NFC advice and help would be much appreciated. Thanks!
Link with everything I have from user manuals to SDK's: https://www.dropbox.com/scl/fo/3186s7dey02t0ec8hqhd6/h?rlkey=tit9jvp95hvt4mys9byhi1rq8&dl=0
Is this running on an Android phone?
If so, can you draw a picture showing how the NFC module is connected to the display?
Which of the documents in Dropbox talk about the NFC module?
Yes, it is on an Android phone.
The module is connected to the display just by an FPC connector. Here is a schematic for the module if that's what you are looking for: https://v4.cecdn.yun300.cn/100001_1909185148/NFC-DEMO_SCH.pdf
This is the document for the NFC module: Dropbox - 复旦微FS1280芯片规格书.zh-CN.en.pdf - Simplify your life
Are trying to replicate the demo in the video in this page?
You are going to need someone who understands written Chinese (or whatever dialect they are using) to understand the flow diagrams and knows enough about NFC readers to find a debug port, assuming there is one, so you can tell what is being received.
Basically yes, I need to send custom generated images with data from an api to be displayed. I guess I'll try by asking the manufacturers about the debug port first. Thanks for your help, I'll keep this post updated when/if I find out more.
