Sending incoming data as Binary to led or light.
I have a problem.
I am working on Project and the project is transmitting data through led or light.
I don’t know how to insert incoming data form Arduino console. and don’t know how to even create a transmitter and receiver.
I am a complete beginner at C++ (and Arduino) and have tried to write some code and this what I come up with. I tried to use a bit method where the transmitter data convert data (like a word or sentence) to bits and sends it out to the receiver and the receiver reassembles the incoming data to words.
#define Laser 13
  pinMode(Laser, OUTPUT);
  String incoming = "Hello World";
  //start bit
  digitalWrite(Laser, HIGH);
  delay(200);
  digitalWrite(Laser, LOW);
  for (int i = 0; i < incoming.length(); i++) {
    char ac = incoming.charAt(i);
    for (int i = 7; i >= 0; i--) {
      byte bytes = byte(ac, i);
      byte bytess = bytes, BIN;
      digitalWrite(Laser, bytess);
      delay(200);
Thanks a lot.
Try bitRead instead
I have already tried but it didn't work.
the laser has turned on once wich
  digitalWrite(LASERPIN, HIGH);
  delay(200);
  digitalWrite(LASERPIN, LOW);
caused it.
jwank:
I have already tried but it didn’t work.
Well, for most definitions of the word, the junk you posted won’t “work” either.
Give bitRead another try
well like I said I have no clue in c++. If it is possible can you write a “good” code down?
I would really I appreciate it if did.
You just need to isolate each bit in “ac” using bitRead repeatedly, and turn the LED on or off appropriately.
I don’t know what the good code would be, because I don’t know what your serial protocol is.
Wouldn't it be a lot simpler to send the data as a Serial transmission. For example use SoftwareSerial with its Tx on the pin connected to the laser and just do something like
mySerial.print("hello world");
With SoftwareSerial you have the option to invert the signal which would probably be a good idea so that the laser is OFF when there is nothing to send. With this option you would also need to use SoftwareSerial at the receiving end.
...R
I really want to do that but there is a tiny tiny problem which is I am new at programming and what I wrote was by searching in documents which i didn’t understand much of it.
If that’s the immediate problem, fix it first.
I am new at programming C/C++*
altho you didn’t help but thanks for your time :).
I have modified the code and it worked
int laser = 13;
  pinMode(laser, OUTPUT);
  byte input;
  while (Serial.available() > 0) {
    input = Serial.read();
    digitalWrite(laser, HIGH);
    delay(10);
    digitalWrite(laser, LOW);
    for (int i = 0; i < 8; i++) {
      digitalWrite(laser, (input & (1 << i)) >> i);
      delay(100);
    delay(10);
Congratulations - you reinvented bitRead.
thanks, and you don't have to be rude about it because I am a beginner if I was a pro then could have made fun of me. anyways thanks for your time.
Pace out.
If I send F (which will be transmitted as: 0100 0110 = ASCII Code of F) from the InputBox 0f Serial Monitor (Fig-1), what will be the ON/OFF conditions of L (built-in LED connected at DPin-13 of Arduino) in response to your sketch of Post#9?
Yeah, for future reference, never, ever write “it didn’t work” without additional detail.
It’s the proverbial red rag to the proverbial bull.
