Sending int over I2C - UNO master, ATtiny85 slabe
I'm trying to use an ATtiny85 to read a MPX5010DP Freescale Pressure Sensor, then send the reading back to an UNO via I2C. It's just an analog read of the sensor.
I've looked at a number of examples, and this is a far as I've gotten with it. I can read the pin, map the 0-1023 reading down to 0-255 and send it as a byte using the below pair of sketches.
On the UNO:
#include "Wire.h";
int selection=0;
int ATtinyAddress=0x26;
unsigned long marktime;
void setup(){
  Wire.begin();
void loop(){
  if (millis()>marktime)
  Wire.requestFrom(ATtinyAddress,1);
  while(Wire.available())
    byte v = Wire.read();
    Serial.println(v);
  marktime+=1000;
on the ATtiny85
#include "TinyWireS.h"
#define I2C_SLAVE_ADDR  0x26
#define Sensor_PIN  3
void setup(){
  pinMode(Sensor_PIN,INPUT);
  TinyWireS.begin(I2C_SLAVE_ADDR);
  TinyWireS.onRequest(requestEvent);
void loop(){
void requestEvent()
  int pressure=analogRead(Sensor_PIN);
  byte pbyte=map(pressure,0,1023,0,255);
  TinyWireS.send(pbyte);
I'd like the full resolution of the Tiny, though. I know I can use lowByte & highByte to get a pair of bytes, and I know I can word() the two back together once I have them on the UNO.
I'm lost at the part of requesting and receiving two bytes, instead of one, and assigning them usable values on the UNO side.
its here - Arduino Playground - WireLibraryDetailedReference -
check requestFrom(address, count);
robtillaart:
its here - Arduino Playground - HomePage -
Thanks for pointing me in that direction. Between that, and plagerizing other code here from the forum (http://forum.arduino.cc/index.php/topic,160680.0.html), I now have a pair of sketches that work, at least. Despite it's function, I'm not fond of this code on the slave.
First, here's the master code so you can see it.
#include "Wire.h";
  Wire.begin();
void loop(){
    byte hb;
    byte lb;
    Wire.requestFrom(ATtinyAddress,2);
    if (Wire.available())
      lb=Wire.read();
      hb=Wire.read();
    int pressure=word(hb,lb);
    Serial.println (pressure);
    marktime+=1000;
Here's the slave code that works.
boolean firstbyte = true;
void setup(){
void loop(){
void requestEvent()
  byte plow;
  byte phi;
  if(firstbyte == true)
  {     // on the first byte we do the math
    plow=lowByte(pressure);
    firstbyte = false;      //so next time though we send the next byte
    TinyWireS.send(plow);
    phi=highByte(pressure);
    TinyWireS.send(phi);
    firstbyte = true;
I don't understand why this code doesn't work. What purpose does the boolean firstbyte serve in the above sketch?
void requestEvent()
  byte plow;
  byte phi;
And, in contrast - this works perfectly if I use a Nano as a slave instead of a tiny.
#include "Wire.h"
int pressure;
void setup(){
  Wire.begin(I2C_SLAVE_ADDR);
  Wire.onRequest(requestEvent);
void requestEvent()
  byte plow=lowByte(pressure);
  byte phi=highByte(pressure);
  byte data[]={plow, phi};
  Wire.write(data, 2);
