I have a problem here and would really appreciate your help.
Most garage opener uses RF, but mine uses IR. I am trying to use Arduino to clone an additional remote and I struggle to buy a replacement. I managed to get an IR Hex code (24B0324B) using Arduino UNO and a IR Receiver. But I struggle when it comes to sending it out. Most guides and videos show people that uses a common TV remote from Sony or Samsung, are there anyone out there tried to do that on less common brands? Thanks so much for your help
How to deal with protocols not supported by IRremote
If you do not know which protocol your IR transmitter uses, you have several choices.
Use the IRreceiveDump example to dump out the IR timing. You can then reproduce/send this timing with the SendRawDemo example. For long codes with more than 48 bits like from air conditioners, you can change the length of the input buffer in IRremote.h.
The IRMP AllProtocol example prints the protocol and data for one of the 40 supported protocols. The same library can be used to send this codes.
If you have a bigger Arduino board at hand (> 100 kByte program space) you can try the IRremoteDecode example of the Arduino library DecodeIR.
Use IrScrutinizer. It can automatically generate a send sketch for your protocol by exporting as "Arduino Raw". It supports IRremote, the old IRLib and Infrared4Arduino.
There is nothing wrong with it. The problem is on my side as it's a bit too complicated for me to understand. Which do you think is the most simple method out of the 4 choices provided? Thanks
