sending keypad value using RF module to LCD
hello...
i try make program the transmit device used keypad then through the RF module to Receive device then LCD will display keypad value. need advise this program..
*trasmiter
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <VirtualWire.h>
LiquidCrystal lcd(3, 4, 5, 6, 8, 11);
const int led_pin = 13;
const int transmit_pin = 7;
const byte ROWS = 4;
const byte COLS = 4;
char key[100];
char hexaKeys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {A0, A1, A2, A3};
byte colPins[COLS] = {A4, A5, 0,1};
Keypad myKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
// Initialise the IO and ISR
vw_set_tx_pin(transmit_pin);
vw_set_ptt_inverted(true);
vw_setup(2000); // Bits per sec
lcd.begin(16,2);
lcd.print("number ID");
lcd.clear();
void loop(){
char key = myKeypad.getKey();
if (key=='1'||key=='2'||key=='3'||key=='4'||key=='5'||key=='6'||key=='7'||key=='8'||key=='9'||key=='0'||key=='A'||key=='B'||key=='C'||key=='D'||key=='*'||key=='#')
lcd.print(key);
if (key=='*')
lcd.clear();
if (key=='#')
char msg[100] = {key};
vw_send ((uint8_t* )msg, 1);
vw_wait_tx();
*********** receiver***********
const int receive_pin = 1;
int i;
vw_set_rx_pin (receive_pin);
vw_set_ptt_inverted (true);
vw_setup (2000); //speed communication bps
vw_rx_start();
uint8_t msg[VW_MAX_MESSAGE_LEN];
uint8_t msglen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(msg,&msglen)) // verify if any data is received
for (i=0; i<msglen; i++)
lcd.print(msg*);*
please CORRECT your post and use the code tags. that's painful to read.
read the simple example on how to deal with the keyPad input. is that what you do here? what happens in your current code when no key is pressed?
In
 if (key=='#')
      vw_wait_tx();
what do you think      char msg[100] = {key}; does? (what's the value of key? when you enter the if? what's {key} ? doing)
