Hi @awneil
Thanks but I couldnt find the variable that is MQTT_MAX_MESSAGE_SIZE
. Dou you know where it is?
here is the library
PubSubClient.h - A simple client for MQTT.
Nick O'Leary
http://knolleary.net
#ifndef PubSubClient_h
#define PubSubClient_h
#include <Arduino.h>
#include "IPAddress.h"
#include "Client.h"
#include "Stream.h"
#define MQTT_VERSION_3_1 3
#define MQTT_VERSION_3_1_1 4
// MQTT_VERSION : Pick the version
//#define MQTT_VERSION MQTT_VERSION_3_1
#ifndef MQTT_VERSION
#define MQTT_VERSION MQTT_VERSION_3_1_1
#endif
// MQTT_MAX_PACKET_SIZE : Maximum packet size. Override with setBufferSize().
#ifndef MQTT_MAX_PACKET_SIZE
#define MQTT_MAX_PACKET_SIZE 256
#endif
// MQTT_KEEPALIVE : keepAlive interval in Seconds. Override with setKeepAlive()
#ifndef MQTT_KEEPALIVE
#define MQTT_KEEPALIVE 15
#endif
// MQTT_SOCKET_TIMEOUT: socket timeout interval in Seconds. Override with setSocketTimeout()
#ifndef MQTT_SOCKET_TIMEOUT
#define MQTT_SOCKET_TIMEOUT 15
#endif
// MQTT_MAX_TRANSFER_SIZE : limit how much data is passed to the network client
// in each write call. Needed for the Arduino Wifi Shield. Leave undefined to
// pass the entire MQTT packet in each write call.
//#define MQTT_MAX_TRANSFER_SIZE 80
// Possible values for client.state()
#define MQTT_CONNECTION_TIMEOUT -4
#define MQTT_CONNECTION_LOST -3
#define MQTT_CONNECT_FAILED -2
#define MQTT_DISCONNECTED -1
#define MQTT_CONNECTED 0
#define MQTT_CONNECT_BAD_PROTOCOL 1
#define MQTT_CONNECT_BAD_CLIENT_ID 2
#define MQTT_CONNECT_UNAVAILABLE 3
#define MQTT_CONNECT_BAD_CREDENTIALS 4
#define MQTT_CONNECT_UNAUTHORIZED 5
#define MQTTCONNECT 1 << 4 // Client request to connect to Server
#define MQTTCONNACK 2 << 4 // Connect Acknowledgment
#define MQTTPUBLISH 3 << 4 // Publish message
#define MQTTPUBACK 4 << 4 // Publish Acknowledgment
#define MQTTPUBREC 5 << 4 // Publish Received (assured delivery part 1)
#define MQTTPUBREL 6 << 4 // Publish Release (assured delivery part 2)
#define MQTTPUBCOMP 7 << 4 // Publish Complete (assured delivery part 3)
#define MQTTSUBSCRIBE 8 << 4 // Client Subscribe request
#define MQTTSUBACK 9 << 4 // Subscribe Acknowledgment
#define MQTTUNSUBSCRIBE 10 << 4 // Client Unsubscribe request
#define MQTTUNSUBACK 11 << 4 // Unsubscribe Acknowledgment
#define MQTTPINGREQ 12 << 4 // PING Request
#define MQTTPINGRESP 13 << 4 // PING Response
#define MQTTDISCONNECT 14 << 4 // Client is Disconnecting
#define MQTTReserved 15 << 4 // Reserved
#define MQTTQOS0 (0 << 1)
#define MQTTQOS1 (1 << 1)
#define MQTTQOS2 (2 << 1)
// Maximum size of fixed header and variable length size header
#define MQTT_MAX_HEADER_SIZE 5
#if defined(ESP8266) || defined(ESP32)
#include <functional>
#define MQTT_CALLBACK_SIGNATURE std::function<void(char*, uint8_t*, unsigned int)> callback
#else
#define MQTT_CALLBACK_SIGNATURE void (*callback)(char*, uint8_t*, unsigned int)
#endif
#define CHECK_STRING_LENGTH(l,s) if (l+2+strnlen(s, this->bufferSize) > this->bufferSize) {_client->stop();return false;}
class PubSubClient : public Print {
private:
Client* _client;
uint8_t* buffer;
uint16_t bufferSize;
uint16_t keepAlive;
uint16_t socketTimeout;
uint16_t nextMsgId;
unsigned long lastOutActivity;
unsigned long lastInActivity;
bool pingOutstanding;
MQTT_CALLBACK_SIGNATURE;
uint32_t readPacket(uint8_t*);
boolean readByte(uint8_t * result);
boolean readByte(uint8_t * result, uint16_t * index);
boolean write(uint8_t header, uint8_t* buf, uint16_t length);
uint16_t writeString(const char* string, uint8_t* buf, uint16_t pos);
// Build up the header ready to send
// Returns the size of the header
// Note: the header is built at the end of the first MQTT_MAX_HEADER_SIZE bytes, so will start
// (MQTT_MAX_HEADER_SIZE - <returned size>) bytes into the buffer
size_t buildHeader(uint8_t header, uint8_t* buf, uint16_t length);
IPAddress ip;
const char* domain;
uint16_t port;
Stream* stream;
int _state;
public:
PubSubClient();
PubSubClient(Client& client);
PubSubClient(IPAddress, uint16_t, Client& client);
PubSubClient(IPAddress, uint16_t, Client& client, Stream&);
PubSubClient(IPAddress, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
PubSubClient(IPAddress, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
PubSubClient(uint8_t *, uint16_t, Client& client);
PubSubClient(uint8_t *, uint16_t, Client& client, Stream&);
PubSubClient(uint8_t *, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
PubSubClient(uint8_t *, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
PubSubClient(const char*, uint16_t, Client& client);
PubSubClient(const char*, uint16_t, Client& client, Stream&);
PubSubClient(const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
PubSubClient(const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
~PubSubClient();
PubSubClient& setServer(IPAddress ip, uint16_t port);
PubSubClient& setServer(uint8_t * ip, uint16_t port);
PubSubClient& setServer(const char * domain, uint16_t port);
PubSubClient& setCallback(MQTT_CALLBACK_SIGNATURE);
PubSubClient& setClient(Client& client);
PubSubClient& setStream(Stream& stream);
PubSubClient& setKeepAlive(uint16_t keepAlive);
PubSubClient& setSocketTimeout(uint16_t timeout);
boolean setBufferSize(uint16_t size);
uint16_t getBufferSize();
boolean connect(const char* id);
boolean connect(const char* id, const char* user, const char* pass);
boolean connect(const char* id, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage, boolean cleanSession);
void disconnect();
boolean publish(const char* topic, const char* payload);
boolean publish(const char* topic, const char* payload, boolean retained);
boolean publish(const char* topic, const uint8_t * payload, unsigned int plength);
boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
boolean publish_P(const char* topic, const char* payload, boolean retained);
boolean publish_P(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
// Start to publish a message.
// This API:
// beginPublish(...)
// one or more calls to write(...)
// endPublish()
// Allows for arbitrarily large payloads to be sent without them having to be copied into
// a new buffer and held in memory at one time
// Returns 1 if the message was started successfully, 0 if there was an error
boolean beginPublish(const char* topic, unsigned int plength, boolean retained);
// Finish off this publish message (started with beginPublish)
// Returns 1 if the packet was sent successfully, 0 if there was an error
int endPublish();
// Write a single byte of payload (only to be used with beginPublish/endPublish)
virtual size_t write(uint8_t);
// Write size bytes from buffer into the payload (only to be used with beginPublish/endPublish)
// Returns the number of bytes written
virtual size_t write(const uint8_t *buffer, size_t size);
boolean subscribe(const char* topic);
boolean subscribe(const char* topic, uint8_t qos);
boolean unsubscribe(const char* topic);
boolean loop();
boolean connected();
int state();
#endif
