Sending messae with SERIAL port
OK. So I will send by serial just one byte, like Serial.println (1, DEC);
and in other board>
if ( Serial.read() == 1); { digtalWrite (pin1, HIGH); }
That is already OK, isnt it?
And about the data rate - Ill try what will do the 115200 on a 40m distance and if it will work Ill let it be...
Anyway, what is soft serial extension and how to setup it?
Thanks J.
JURA,
I think you will have trouble at 40m with speeds greater than 9600. See http://www.lammertbies.nl/comm/info/RS-232_specs.html for a discussion of RS232 cable length. I haven’t tried any of the wireless solutions, but perhaps these are called for?
I think your software solution is fine, but omit that trailing semicolon in
if ( Serial.read() == 1); <— take this ; away!
This is an unfortunate C mistake that compiles fine, but doesn’t give you the results you want.
The software serial page is here: http://arduino.cc/en/Reference/SoftwareSerial
Mikal
