I have working code for a midi foot controller that sends midi note on/off each time you press a switch (and displays a 4 digit 7 segment number)
However, my hardware device requires a “long press” for a specific function, so I need to send the note on immediately but only send the note off when the button is released. I’m still a relative beginner and the coding logic of this is defeating me.
Technically, this only applies for case 0, but I put it outside the switch statement since it wouldn’t hurt the other cases and I thought it might be easier!
Here’s the code so far, which works apart from the highlighted area, which was my best guess. Any help really appreciated
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#include <TM1637Display.h>
uint8_t arse[] = {
0, 0, 0, 0,
SEG_A | SEG_B | SEG_C | SEG_E | SEG_F | SEG_G, // A
SEG_E | SEG_G, // r
SEG_A | SEG_C | SEG_D | SEG_F | SEG_G, // s
SEG_A | SEG_D | SEG_E | SEG_F | SEG_G, // E
// Constants
#define SWITCH1 2
#define SWITCH2 3
#define SWITCH3 4
#define SWITCH4 5
#define SWITCH5 6
#define SWITCH6 7
#define SWITCH7 8
#define SWITCH8 9
#define SWITCH9 10
#define SWITCH10 12
#define SWITCHES 10 // how many switches?
#define BOUNCEDELAY 200
const int CLK = A0; //Set the CLK pin connection to the display
const int DIO = A1; //Set the DIO pin connection to the display
TM1637Display display(CLK, DIO); //set up the 4-Digit Display.
// Variables:
int notes[SWITCHES] = { 38, 39, 40, 41, 42, 49, 48, 44, 43 };
int switches[SWITCHES] = { SWITCH1, SWITCH2, SWITCH3, SWITCH4, SWITCH5, SWITCH6, SWITCH7, SWITCH8, SWITCH9, SWITCH10 };
int switchState[SWITCHES] = { HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH }; // Initial state of switch is high due to internal pullup
int currentSwitch = 0;
int delayStatus = 0;
int bank = 0; // initial bank
int numbanks = 2; // how many banks?
MIDI.begin(1); // start serial with midi baudrate 31250 or 38400 for debugging
Serial.begin(31250);
Serial.flush();
// Serial.begin(9600); // for serial monitor:
display.setBrightness(0x0a); //set the diplay to maximum brightness
for (int i=0; i<5; i++) // show "welcome" message
display.setSegments(arse+i);
uint8_t data[] = {0x0, 0x0, 0x0, 0x0};
display.setSegments(data); // blank the display
for( currentSwitch = 0; currentSwitch < SWITCHES; currentSwitch++ ) // Setup Switches
pinMode( switches[currentSwitch], INPUT ); // Set pin for switch
digitalWrite( switches[currentSwitch], HIGH ); // Turn on internal pullup
display.showNumberDec(bank,false,1,0);
for( currentSwitch = 0; currentSwitch < SWITCHES; currentSwitch++ ) // check each switch
if ( (digitalRead(switches[currentSwitch]) != switchState[currentSwitch] ) && (switchState[currentSwitch] == HIGH) ) // switch has changed
MIDI.sendNoteOn(notes[currentSwitch],127,1); // Send a Note
// this is the part that doesn't work
if ( (digitalRead(switches[currentSwitch]) != switchState[currentSwitch] ) && (switchState[currentSwitch] == LOW) ) // button was released since last checked
MIDI.sendNoteOff(notes[currentSwitch],0,1); // Stop the note
switch( currentSwitch )
case 0: //
display.showNumberDec(0,false,1,2); // record 38
display.showNumberDec(1,false,1,3);
case 1: //
display.showNumberDec(0,false,1,2); // overdub 39
display.showNumberDec(2,false,1,3);
case 2: //
display.showNumberDec(0,false,1,2); // multiply 40
display.showNumberDec(3,false,1,3);
case 3: //
display.showNumberDec(0,false,1,2); // insert 41
display.showNumberDec(4,false,1,3);
case 4: //
display.showNumberDec(0,false,1,2); // mute 42
display.showNumberDec(5,false,1,3);
case 5: //
display.showNumberDec(0,false,1,2); // rev 49
display.showNumberDec(6,false,1,3);
case 6: //
display.showNumberDec(0,false,1,2); // speed 48
display.showNumberDec(7,false,1,3);
case 7: //
display.showNumberDec(0,false,1,2); // next 44
display.showNumberDec(8,false,1,3);
case 8: //
display.showNumberDec(0,false,1,2); // undo 43
display.showNumberDec(9,false,1,3);
case 9: //
bank ++;
if (bank > numbanks) (bank = 0);
delay( BOUNCEDELAY );
} // end if switch has changed
switchState[currentSwitch] = digitalRead( switches[currentSwitch] );
} // end check all switches
} // end void loop
