Sending Messages
Can someone give me a simple code of sending a "Hi" message on Whatsapp or Telegram using esp8266 or esp32. I had tried many things but failed with esp8266. Should use esp32 ?
Here are the codes I had used :
#include <ESP8266WiFi.h>
#include <SoftwareSerial.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
const char* ssid = "XXXXX";
const char* password = "XXXXX;
#define BOTtoken "XXXXX";
#define CHAT_ID "XXXXX";
SoftwareSerial serial(5, 4); // RX, TX
X509List cert(TELEGRAM_CERTIFICATION_ROOT);
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
  serial.begin(9600);
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  // Read float value from Arduino via RX pin
  float receivedFloat = receiveFloatData();
  if (!isnan(receivedFloat)) {
    // Construct the message to be sent
    String message = "Name: Sam\n" + String(receivedFloat);
    // Send the message to the specified Telegram group
    sendTelegramMessage(message);
    delay(5000); // Adjust the delay as needed
float receiveFloatData() {
  float data = 0.0;
  while (serial.available() > 0) {
    char incomingByte = serial.read();
    if (incomingByte == '\n') {
      break; // End of the float value
    data = data * 10.0 + (incomingByte - '0');
  return data;
void sendTelegramMessage(String message) {
  if (bot.sendMessage(chatId, message, "Markdown")) {
    Serial.println("Message sent successfully");
    Serial.println("Failed to send message");
const char* ssid = "XXXXX"; // Enter your WIFI SSID
const char* password = "XXXXX"; // Enter your WIFI Password
#define BOTtoken "XXXXX" // Enter the bottoken you got from botfather
#define CHAT_ID "XXXXX" // Enter your CHAT_ID you got from CHAT_ID bot
SoftwareSerial mySerial(5, 4); // RX, TX
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
// Function declaration for sendMessage
void sendMessage(String message);
mySerial.begin(9600);
configTime(0, 0, "pool.ntp.org");
client.setTrustAnchors(&cert);
WiFi.mode(WIFI_STA);
int a = 0;
Serial.print(".");
a++;
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
sendMessage("Wifi Connected!");
sendMessage("System has Started!!");
String msg = mySerial.readStringUntil('\r');
Serial.println(msg);
sendMessage(msg);
delay(5000);
// Function definition for sendMessage
void sendMessage(String message) {
int response = bot.sendMessage(CHAT_ID, message, "Markdown");
if (response == 200) {
else {
Serial.print("Failed to send message. HTTP error code: ");
Serial.println(response);
const char* botToken = "XXXXX";
const char* chatId = "XXXXX";
UniversalTelegramBot bot(botToken, client);
serial.begin(9600);
// Connect to Wi-Fi
float data = 0.0;
return data;
bot.sendMessage(CHAT_ID, "ALERT! MOTION DETECTED!!", "");
#include <ESP8266HTTPClient.h>
#include <UrlEncode.h>
// add +international_country_code + phone number
String mobile_number = "XXXXX";
String api_key = "XXXXX";
void send_whatsapp_message(String message) {
String API_URL = "https://api.whatabot.net/whatsapp/sendMessage?apikey=" + api_key + "&text=" + urlEncode(message) + "&phone=" + mobile_number;
WiFiClient client;
HTTPClient http;
if (!http.begin(client, API_URL)) {
Serial.println("Failed to begin HTTP connection");
return;
int http_response_code = http.GET();
if (http_response_code == HTTP_CODE_OK) {
Serial.println("WhatsApp message sent successfully");
Serial.println("Error sending the message");
Serial.print("HTTP response code: ");
Serial.println(http_response_code);
http.end();
Serial.println("Connecting to Wi-Fi Access Point");
Serial.print(".");
Serial.println("\nConnected to Wi-Fi IP Address:");
send_whatsapp_message("Hi, This is ESP8266!");
Hello, do yourself a favour and please read How to get the best out of this forum and post accordingly (including code with code tags and necessary documentation for your ask like your exact circuit and power supply, links to components etc).
➜ click the pencil button under your post to edit it and fix it by adding code tags where relevant.
Your topic has been moved to a more suitable location on the forum as it does not seem to indicate problems with the IDE.
