Sending Multiple Packets using NRF24L01+ and RF24/RF24network
Hello,
I'm a beginner to using the RF24network and i'm having trouble organizing the data when it hits the receiver. I have a temperature sensor and an accelerometer each hooked up to their respective Unos. I can send over data from the temperature sensor without issue in one payload but i'm having trouble getting the network to recognize a separate packet. When both arduinos send over the data, it is getting mixed up together so the output has the correct numbers but they are jumbled.
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
RF24 radio(8,9);
RF24Network network(radio);
const uint16_t home_node = 00;
const uint16_t temp_node = 01;
const uint16_t accel_node = 02;
struct payload_t {
  int temp;
  int humi;
struct accelpayload_t {
  int x;
  int y;
  int z;
void setup(void)
  Serial.println("");
  Serial.println("Hello, my name is GEORGE and I will collect the following data for you: TEMPERATURE, HUMIDITY, LOCOMOTION");
  Serial.println("");
  SPI.begin();
  radio.begin();
  network.begin(/*channel*/ 92, /*node address*/ home_node);
void loop(void){
  network.update();                  // Check the network regularly
  while ( network.available() ) {     // Is there anything ready for us?
    RF24NetworkHeader header;
    payload_t payload;
    //temp/humi
    network.read(header,&payload,sizeof(payload));
    Serial.print(" Temperature ");
    Serial.println(payload.temp);
    Serial.println(" Celsius ");
    Serial.print(" Humidity ");
    Serial.println(payload.humi);
    Serial.println(" % ""relative");
    RF24NetworkHeader accelheader;
    accelpayload_t accelpayload;
    network.read(accelheader,&accelpayload,sizeof(accelpayload));
      //accel
    Serial.print("accelerations are x, y, z: ");
    Serial.print(accelpayload.x);    // print the acceleration in the X axis
    Serial.print(" ");       // prints a space between the numbers
    Serial.print(accelpayload.y);    // print the acceleration in the Y axis
    Serial.println(accelpayload.z);  // print the acceleration in the Z axis
Now i realize the end of the code in the loop is completely wrong so it is essentially a placeholder at this point. If anyone could point me in the right direction on how to organize my payloads that would be amazing.
Thank you!
accelSensormay6TX.ino (1.63 KB)
workingTempSensorMay9RX.ino (1.7 KB)
workingTempSensorMay9TX.ino (1.62 KB)
