Sending multiple values from Arduino to Matlab (serial)
hi there,
i searched the forum some hints with my problem, but i didnt find the right solution.
i want to send multiple valules (read with my arduino inputs A0 A1 A2...) to Matlab.
i want to send something like this with serial
A013 B123 C534 D023 E234 F235 A014 B124...... over and over again (were A=A0, B=A1, C=A2...)
i can do it the other way, from Matlab to Arduino with switch cases, but i dont know how to do this in matlab.
here is my code with Arduino:
/*Send several Values to Matlab
#include <Servo.h>
Servo meinServo;
int ServoRead = 12;
int LDR0;
int LDR1;
int messung = 0;
int positionservo = 90;
int messIntervall = 50; // measure intervall
int wert = 0;
unsigned long zeitLetzteMessung = 0;
int sensitivity = 30; //
float servospeed = 1; //
  meinServo.attach(ServoRead);
  meinServo.write(positionservo);
  establishContact();
  LDR0 = analogRead(A1);
    LDR1 = analogRead(A2);
    if(millis() - zeitLetzteMessung > messIntervall)
      messung = (LDR1 - LDR0);
      if(messung > sensitivity)
      { wert = 1*servospeed;}
      if(messung < -(sensitivity))
      { wert = -1*servospeed;}
      if(messung < sensitivity && messung > -(sensitivity))
      {wert = 0;}
      positionservo= positionservo + wert;
      if(positionservo <= 0)
      {positionservo = 0;}
      if(positionservo >= 179)
      {positionservo = 179;}
      zeitLetzteMessung = millis();
    Serial.println(A); %Channel A0
    Serial.println(LDR0);
    Serial.println(B); %Channel A1
    Serial.println(LDR1);
    Serial.println(C); %Channel A2
    Serial.println(0);
    Serial.println(D); %Channel A3
    Serial.println(0);
    Serial.println(E); %Channel A4
    Serial.println(0);
    Serial.println(F); %Channel A5
    Serial.println(0);
   void establishContact() {
     while (Serial.available() <= 0) {
       Serial.println('A', BYTE);   // send a capital A
       delay(300);
here s my Matlab code
function varargout = mygui(varargin)
gui_Singleton = 1;
gui_State = struct('gui_Name',       mfilename, ...
                   'gui_Singleton',  gui_Singleton, ...
                   'gui_OpeningFcn', @mygui_OpeningFcn, ...
                   'gui_OutputFcn',  @mygui_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin && ischar(varargin{1})
    gui_State.gui_Callback = str2func(varargin{1});
end
if nargout
    [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
end
function mygui_OpeningFcn(hObject, eventdata, handles, varargin)
handles.output = hObject;
guidata(hObject, handles);
% changeIcon
jFrame=get(handles.figure1,'javaframe');
jIcon=javax.swing.ImageIcon('icon.gif');
jFrame.setFigureIcon(jIcon);
% changeUserData
set(handles.pushbutton_run,'UserData',0);
function varargout = mygui_OutputFcn(hObject, eventdata, handles)
varargout{1} = handles.output;
function pushbutton_run_Callback(hObject, eventdata, handles)
if get(handles.pushbutton_run,'UserData')==1, return; end
set(handles.pushbutton_run,'UserData',1);
x = get(handles.pushbutton_run,'UserData');
disp('RUN')
s1 = serial('/dev/ttyACM0');    % define serial port
s1.BaudRate=115200;               % define baud rate
set(s1, 'terminator', 'LF');    % define the terminator for println
fopen(s1);
try                             % use try catch to ensure fclose
                                % signal the arduino to start collection
w=fscanf(s1,'%s');              % must define the input % d or %s, etc.
if (w=='A')
    display(['Collecting data']);
    fprintf(s1,'%s\n','A');     % establishContact just wants
                                % something in the buffer
end
i=0;
%value = [];
while x==1;
    y=fscanf(s1,'%d')
    y=num2str(y);
    set(handles.ausgabe,'String',y);
    if get(handles.pushbutton_run,'UserData')==0
    set(handles.ausgabe,'String','0');
    pause(0.1);
        %cla;
    end
    pause(0.025); % Lese-Intervall, muss kleiner sein als Abtastintervall bei Arduino
    clc;
end
fclose(s1);
catch exception
    fclose(s1);                 % always, always want to close s1
    %throw (exception);
end
function pushbutton_stop_Callback(hObject, eventdata, handles)
disp('STOP')
function ausgabe_Callback(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function ausgabe_CreateFcn(hObject, eventdata, handles)
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
i think i have to send bytes, but i dont know how to do this exactly.
in my matlab code i connect with a gui interface.
if run is pressed, it connects and reveives the data in real time
if i hit stop, the connection is closed
no i want to display multiple values within the gui.
anybody can help me?
--moe
something like this....
  printVal( 'A', analogRead(A0));
  printVal( 'B', analogRead(A1));
  printVal( 'C', analogRead(A2));
  printVal( 'D', analogRead(A3));
  printVal( 'E', analogRead(A4));
  printVal( 'F', analogRead(A5));
  // Serial.println();  // start a new line every 6 readings
void printVal(char c, int val)
  Serial.print(c);
  if (val < 1000) Serial.print('0');  // optional remove leading zeros
  if (val < 100) Serial.print('0');
  if (val < 10) Serial.print('0');
  Serial.print(val, DEC);
  Serial.print(" , ");   // use your favo separator here e.g. a comma separated file ?
