Hi, i'm trying to send multiple values from a c# program to arduino trought serial, but i only know how to send a string.
An example: i have two Int's in my c# program (X and Y), and i want to send this to arduino, and convert again in two Int's.
c# code example: (assuming there is no way to send it directly as an integer)
int x = 50;
int y = 100;
SerPort.Write(String.Format("{0}{1}", x, y));
and I don't know how to take these values in arduino separately, and convert them to integers again
See Serial input basics - updated or experiment with the Serial.parseInt() function
gcjr
September 13, 2021, 10:06am
3
a common approach is to received a complete line of information, terminated with a specific character such as a newline, '\n' (i.e. readBytesUntil() ). of course values/fields should be separated in that line by a non-value character (e.g., space, comma)
sscanf can then be used to extract specific values from the complete line
If you add a comma, you can separate x and y . Else you wil never know if e.g. 123 means x = 1 and y = 23 or x = 12 and y = 3.
And to make use of the serial input basics example with startmarker and endmarker
SerPort.Write(String.Format("<{0},{1}>", x, y));
system
Closed
January 11, 2022, 4:52pm
5
