sending multiple values to processing
Hi guys,
im a novice at processsing and java, any help would be really appreciated!
Here's my arduino code:
Serial.print(sonar1.ping_cm(), DEC);
Serial.print(",");
Serial.println(sonar2.ping_cm(), DEC);
I pass it to processing successfully. My problem is that I need these two values to continually send their values to processing and I don't know how to separate them into two different arrays.
Here's my processing code:
void serialEvent(Serial myPort) {
String MyString = myPort.readString();
if (MyString != null) {
MyString=trim(MyString);
String[] values = split(MyString, ',');
d1 = int(map(Integer.parseInt(values[0]), 0, 200, 400, 800));
d2 = int(map(Integer.parseInt(values[1]), 0, 200, 400, 800));
Whenever I use values[1] I get a "Error, disabling serialEvent() for COMx - NULL"
Eventually I'll need to send 4 values instead of just 2 but for now I just want to get this working. Thanks in advance!
Values don't send themselves. Code sends values in variables.
That was SOME of the code. For that, you get some of the answer. You need to... (More later).
