Sending multiple variables from processing to arduino
Hey guys,
after searching the internet for about 3 days, i have enough courage to ask.
I´m looking for a piece of code that does this:
I have 2 variables in processing, a and b.
and i want them to be sent through the serial port to the arduino.
Here i want to have again the same variables. a and b.
Sending one variable is quite easy, but how is it done with more then one?
How am i able to say, hey this is the value of variable a and this for variable b.(like marking them)
It would be the biggest Christmas present for me fixing this problem.
Thank you very much,
Johannes
Of what type?
Just like one.
Are you sending in binary or ASCII? If ASCII, "A=xxx, B=yyy" would work. If binary, there is no need to label them. The bytes are sent in the order you specify.
hey paul,
thank you for your answers.
  1. The variables a and b are numbers between 0 and 180 that are constantly changing.
  2. if i send them in a specified order, (a,b,a,b....)which could look like (121,9,109,40....)
    and i read the serial monitor with arduino, how do i say: ok the first one is a, the second one is b, the third one is a etc. ...?
    (on the arduino side)
Isnt there a safer method, because if there appears a mistake (like missing one number), perhaps a b becomes an a or is it unnecessary?
cheers,
johannes
Like so?
variable a = 22;
variable b = 29;
No. Send them like "<121,9><109,40>..."
Then, you know where the data for one iteration starts and where it ends.
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Where the comment "Process the packet" is, inData would contain "121,9" which you can parse using strtok(), and convert to values using atoi(). There is no risk, then, of getting the numbers out of order.
Using start and end of packet markers makes this impossible. There is still the possibility of data loss, but lost start or end markers are handled. Lost characters in between are possible, and there are ways to deal with this possibility. How to do send depends on the severity of a lost/corrupted value.
Dear Paul,
thank you a lot.
I´m going to look at the code the whole day, till i´m completely into it.
When i got it and it is working im going to tell you.
thank you a lot again,
Johannes
Dear Paul,
thank you for your code but i cant accept that it is so complicated to send two changing numbers from processing to arduino.
isn´t there an example for the processing and the arduino code where you see, a and b in processing, and then a and b in arduino.
I refuse to believe that there isn´t a less complicated solution.
I still think there is this, one line code in processing and one line code in arduino.
please help me,
johannes.
Good luck finding that one line...
does anyone have a working example?
something like this?
http://anthonymattox.com/serial-communication-sending-variables-to-the-arduino
For a number of reasons, that's not a good example.
Blind belief may work in spiritual matters, but I'm afraid microcontrollers are innoculated against it before leaving the fab.
Do you have a better example?
that would be great!
peace guys,
johannes.
If you need to guarantee that your data arrives in correct pairs, Paul's code is the sort of thing you need. It can be less complex, but only if you are prepared to forget about data integrity.
