Sending MySQL Query Including RFID Value To Return Credit Amount
Project so far: I have a website running php where a user can input their RFID card number, debit card details and make payment via Stripe. Their RFID card number, name, and amount paid is stored in a local MySQL database. The database runs a trigger whenever there is a change that updates a table including the persons RFID number and the total amount they have paid.
When the person swipes their card on the Arduino it needs to send a query with this RFID number to the database and return the credit amount for that card and store it in a variable. The problem is, I'm having trouble sending the RFID card number(obtained from swiping the card) in a MySQL query(MySQL Connector library). Code I have is:
#include <SPI.h>
#include <MFRC522.h>
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#define SS_PIN 53 //rfid pins
#define RST_PIN 5
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr(192,168,8,181);  // IP of the MySQL *server* here
char user[] = "aaron";              // MySQL user login username
char password[] = "mypassword";        // MySQL user login password
// query to grab credit amount attached to rfid card
const char QUERY_CREDIT[] = "SELECT amount FROM paypage.colate WHERE product = %d;";
char query[128];
EthernetClient client;
MySQL_Connection conn((Client *)&client);
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Set up the ethernet and serial.
 while (!Serial); // wait for serial port to connect
 Ethernet.begin(mac_addr);
 Serial.println("Connecting...");
 if (conn.connect(server_addr, 3306, user, password)) {
     Serial.println("Connected");
   Serial.println("Connection failed.");
SPI.begin();
mfrc522.PCD_Init();
Serial.print("Startup");
pinMode (2, OUTPUT); //Pin 2 gets defined as output (here we are going to connect the LED)
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
if ( ! mfrc522.PICC_ReadCardSerial())
return;
long code=0;
for (byte i = 0; i < mfrc522.uid.size; i++)
code=((code+mfrc522.uid.uidByte[i])*10);
Serial.print("The Card number is:");
Serial.println(code);
Serial.println("Obtaining amount data.");
 Serial.println("\nRunning SELECT and printing results\n");
 // Initiate the query class instance
 MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
 sprintf(query, QUERY_CREDIT, code);
 // Execute the query
 cur_mem->execute(query);
 // Fetch the columns and print them
 column_names *cols = cur_mem->get_columns();
 for (int f = 0; f < cols->num_fields; f++) {
   Serial.print(cols->fields[f]->name);
   if (f < cols->num_fields-1) {
     Serial.print(", ");
 // Read the rows and print them
 row_values *row = NULL;
 do {
   row = cur_mem->get_next_row();
   if (row != NULL) {
       Serial.print(row->values[f]);
         Serial.print(", ");
 } while (row != NULL);
 // Deleting the cursor also frees up memory used
 delete cur_mem;
} //End of the sketch
The serial monitor doesn't output the value from the database.
How does a product (ID) relate to an RFID value?
The value read from the RFID card is NOT an int, to the %d format specifier is inappropriate.
The value is an array of bytes. Pretending that each byte has a range from 0 to 9 is wrong. You can NOT meaningfully construct a long that way.
That code you started with is the crappiest example on the internet. I'd recommend that you understand the functions that it uses and then sh*tcan that code and start over.
