sending names of objects of MQTT as strings via Wifi Manager or any web page
hello Amazing community!
i was just working with Ada fruits MQTT library and trying to publish requests......now there is name of the publishing object ,i was wondering that is it possible i would take this name of object as a wifimanager parameter ,but that parameter happens to be string.....
this is what the publishing object looks like
Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt,AIO_USERNAME "/feeds/photocell");
thanks already
can you clarify what's the question?
oops...i am sorry
what i want is like this
i want to send name of topic to my device via wifimanager....
since the name of topic is not string how will i do this
thats it
thanks for reply anyways
if it's not a string, what is it?
i dont think its a string.....but i really am not sure
for its i got it like this
#define s "/feeds/photocell"
is "/feeds/photocell" a string here?
thanks for reply
It’s a cString (read this)
cool
but when i put it into string and then as parameter in object photo cell...it dosent work
I added a link whilst you were answering
thanks J-M-L
i got it
but when i try to put string a a parameter into the given object of publish it just dosent work
here it is
#define AIO_USERNAME "sabishaw"
String s="/feeds/photocell";
Adafruit_MQTT_Publish photocell =Adafruit_MQTT_Publish(&mqtt,AIO_USERNAME +s);
just wont work
... you want me to upload whole code?
You need to concatenate both beforehand into a cString buffer or do a String(AIO_USERNAME ) + s
doing so i got this error message
no matching function for call to 'Adafruit_MQTT_Publish::Adafruit_MQTT_Publish(Adafruit_MQTT_Client*, StringSumHelper&)'
heres what i did
Adafruit_MQTT_Publish photocell =Adafruit_MQTT_Publish(&mqtt,String(AIO_USERNAME)+s);
I’m on my smartphone
Find the signature for Adafruit_MQTT_Publish() to see what parameter type is expected . If it’s a cString (a char * or const char *) then you need to build it using strcpy() and strcat() into a char buffer
thanks J-M-L
i ma newbie,i dont quite understand ...could you please elaborate
thanks
char buffer[50]; // has to be long enough
strcpy(buffer, AIO_USERNAME);
strcat(buffer, s);
Then pass buffer as parameter (if both are cStrings)
Damn....it gave me this error message
exit status 1
expected constructor, destructor, or type conversion before '(' token
highlighting
strcat(buffer, s);
what does it mean?????????
Sorry - I’m on my iPad now - seeing the whole conversation better
So you have
(why would you use the String class is another discussion...)
So you do either
String p = String(AIO_USERNAME) + s;
And then call Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt,p.c_str());
Or
strcat(buffer, s.c_str());
And then call Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt,buffer);
But as both are known you can also just call Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt,”sabishaw/feeds/photocell”);
So you have
Code: [Select]
So you do either
Code: [Select]
And then call
Code: [Select]
exit status 1
expected unqualified-id before string constant
and this behaviour made me to question if it is a string or not, anyways
And then call
Code: [Select]
error message
exit status 1
Code: [Select]
Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt,"sabishaw/feeds/photocell");
since i am just exprimenting with Adafruit_MQTT_Publish for now,so these strings are known..what i want is,sending these strings as parameters of wifimanager,so that i wouldn't have to hardcode the topic..
thanks for your prompting replies
converting Strings to char * can be done like this
  String TheString="Whatever";
  char charpointer[TheString.length()+1];
  TheString.toCharArray(charpointer,TheString.length()+1);
Post Full code
Where are you doing this ? It has to be in a function, not in the global variable definitions
sure
please dont pay attention to other parts..... for now i was just dealing with the parts i discussed here so far
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883                   // use 8883 for SSL
#define AIO_KEY         "5858613ad24e14c19cc"
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
//#define a AIO_USERNAME s;
AIO_USERNAME+=s;
Adafruit_MQTT_Publish photocell =Adafruit_MQTT_Publish(&mqtt,buffer);
void MQTT_connect();
uint32_t x=0;
//define your default values here,if there are different values in config.json, they are overwritten.
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[34] = "YOUR_BLYNK_TOKEN";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_server"] = mqtt_server;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  Serial.println("local ip");
 MQTT_connect();
 delay(5000);
Serial.print(F("\nSending photocell val "));
  Serial.print(x);
  Serial.print("...");
  if (! photocell.publish(x++)) {
    Serial.println(F("Failed"));
  else {
    Serial.println(F("OK!"));
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
