Hey guys,
So, been working on my project, which involves a JPEG image from an SD card getting sent over LoRa to a Adafruit Feather M0 WiFi - ATSAMD21 + ATWINC1500 with a LoRa wing.
I have the code for the Arduino with an SD card, where the receiving feather sends a number for which packet it wants, and the arduino replies. Each packet can have a max length of 251 but I made all my packets 250 bytes long for simplicity.
My question is, On the feather side, how should I store the information, then send it over HTTP to a server? I can use the feather to make GET and POST requests, however, I have no idea how to send the image.
Note, there is more to the project by a long shot, these scripts are modified examples so I can add the code to send and receive images to the full scripts after I figure it out.
Arduino with SD card-
// rf95_reliable_datagram_server.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple addressed, reliable messaging server
// with the RHReliableDatagram class, using the RH_RF95 driver to control a RF95 radio.
// It is designed to work with the other example rf95_reliable_datagram_client
// Tested with Anarduino MiniWirelessLoRa, Rocket Scream Mini Ultra Pro with the RFM95W
#include <RHReliableDatagram.h>
#include <RH_RF95.h>
#include <SPI.h>
#include <SD.h>
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 driver(6, 3);
// Class to manage message delivery and receipt, using the driver declared above
RHReliableDatagram manager(driver, SERVER_ADDRESS);
// Need this on Arduino Zero with SerialUSB port (eg RocketScream Mini Ultra Pro)
//#define Serial SerialUSB
// Rocket Scream Mini Ultra Pro with the RFM95W only:
// Ensure serial flash is not interfering with radio communication on SPI bus
// pinMode(4, OUTPUT);
// digitalWrite(4, HIGH);
pinMode(5, OUTPUT);
digitalWrite(5, HIGH);
delay(100);
SPI.begin();
while (!Serial) ; // Wait for serial port to be available
while (!SD.begin(8)) {
Serial.println(F("SD Card Error!")); delay(1000);
Serial.println(F("SD Card detected."));
digitalWrite(5, LOW);
delay(10);
delay(10);
if (!manager.init())
Serial.println("init failed");
// Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
// driver.setTxPower(23, false);
// If you are using Modtronix inAir4 or inAir9,or any other module which uses the
// transmitter RFO pins and not the PA_BOOST pins
// then you can configure the power transmitter power for -1 to 14 dBm and with useRFO true.
// Failure to do that will result in extremely low transmit powers.
// driver.setTxPower(14, true);
// You can optionally require this module to wait until Channel Activity
// Detection shows no activity on the channel before transmitting by setting
// the CAD timeout to non-zero:
driver.setCADTimeout(10000);
if (!driver.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
// Dont put this on the stack:
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
int fileLen;
void getSDData(int packNum, uint8_t from) {
Serial.println("Retriving SD data...");
File file = SD.open("1.JPG", FILE_READ);
fileLen = file.size();
boolean kg = file.seek(packNum * 250);
if (kg == true) {
if (fileLen - packNum * 250 >= 250) {
Serial.println("Sending 250 byte packet");
Serial.println(file.position());
uint8_t data[250];
for (int i = 0; i <= 250; i++) {
data[i] = file.read();
if (!manager.sendtoWait(data, sizeof(data), from))
Serial.println("sendtoWait failed");
else {
int left = fileLen - file.position();
uint8_t data[left];
for (int i = 0; i <= left; i++) {
else {
uint8_t data[] = "NA";
if (manager.available())
// Wait for a message addressed to us from the client
uint8_t len = sizeof(buf);
uint8_t from;
if (manager.recvfromAck(buf, &len, &from))
Serial.println("\n-----");
Serial.print("got request from : 0x");
Serial.print(from, HEX);
Serial.print(": ");
Serial.println((char*)buf);
int sec = String((char*)buf).toInt();
getSDData(sec, from);
// Send a reply back to the originator client
Current feather code-
#include <SPI.h>
#define RFM95_RST 11 // "A"
#define RFM95_CS 10 // "B"
#define RFM95_INT 6
RH_RF95 driver(RFM95_CS, RFM95_INT);
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
delay(100);
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (1);
uint8_t photobuf[50][251];
int packNum = 0;
char pm[2];
itoa(packNum, pm, 10);
if (packNum <= 50) {
Serial.println("Sending to rf95_reliable_datagram_server");
// Send a message to manager_server
if (manager.sendtoWait((uint8_t *)pm, 2, SERVER_ADDRESS))
// Now wait for a reply from the server
uint8_t from;
if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
Serial.print("got reply from : 0x");
Serial.print(": ");
Serial.println(sizeof((char*)buf));
String in = (char*)buf;
if(in=="NA"){
printMemory();
Serial.println("NA FOUND");
// memcpy(buf, photobuf[packNum] [ 251]);
for (int i = 0; i < 250; i++) {
photobuf [packNum][i] = buf [i];
packNum++;
Serial.println("No reply, is rf95_reliable_datagram_server running?");
else {
printMemory();
void printMemory(){
Serial.println("-----------------------------------");
for (int a = 0; a < 50; a++) {
for (int i = 0; i < 251; i++) {
Serial.write(photobuf[a][i]);
Serial.print("\n");
while (true);
