I'm trying to build a system that receives inputs from multiple foot switches (min 2, max 8 ) which sends its signal via USB.
This is easy by means of digitalRead and Serial.write, anyway if I have multiple pedals, because the digitalRead on each input pin of the foot switches are serailly read, there could be delays among them.
Therefore, because I want that these foot switches will work in parallel, I would like to use the arduino ports and send their state via USB... But I'm not succeding in this, the serial monitor is not showing any signal at all!
Here the code:
DDRB = B11111111; // set PORTB (digital 13~8) to outputs
/*I've also tried by setting it at B00000000;*/
// Read data from serial communication
if (Serial.available() > 0)
Serial.write(PINB);//trying if this works
Serial.flush();
Serial.write(PORTB);//trying if this works
Serial.flush();
It is pointless to call Serial.flush() after every write. It is pointless to cast the byte PINB to an int to pass the data to a function that expects a byte.
