Sending PROGMEM strings over HC12
Hi all,
As the subject suggests I am just after a simple yes or know really. Can I use __FlashStringHelper() to send C strings stored in PGM over a wireless connection via HC12 modules.
I don’t want to start down that route if it’s not possible
No code yet, just asking before I start writing.
cheers
I don't know any function named __FlashStringHelper().
There is a class __FlashStringHelper. Pointers to this class are used by the Print class to signal access to PROGMEM data.
If your HC12 object derives from Print, pointers to __FlashStringHelper could be used to signal to the Print methods that the data resides in PROGMEM.
Hi
Thanks for the reply
I don't think I explained that very well, here's kind of what I had in mind:
 HC12.println((__FlashStringHelper*)table1[messageNum]);
Does that make sense?
Cheers
Larp-fx: here's kind of what I had in mind:
If the class HC12 derives from Print that should work (given a correct definition of table1[]).
Awesome, cheers
Another quick question if I may.
On the receiving end should i be looking for a String or char? The message being sent is a constant char stored in PROGMEM
cheers
Larp-fx:
How could I answer that, without seeing both programs?
