Sending Pulse rate via 433mhz rf
Hello goo day, I need some help receiving values from my transmitter,
It show my pulse rate sensor to my serial monitor if it is String, but broken or square icon if i try to send int.
RECEIVER:
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
 RH_ASK driver(2000, 2, 9, 10); // ESP8266: do not use pin 11
    Serial.begin(9600);	// Debugging only
    if (!driver.init())
         Serial.println("init failed");
    uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
    uint8_t buflen = sizeof(buf);
    if (driver.recv(buf, &buflen)) // Non-blocking
	int i;
	String str= "";
  for(int i = 0; i <buflen; i++){
  str += (char)buf[i];
  Serial.println(str);
TRANSMITTER:
#include <RH_ASK.h>
///////TEST
int BPM = 0;
int BPMdata;
RH_ASK driver(2000, 9, 2, 5); // ESP8266: do not use pin 11
  ////TEST
    if (!driver.init())
   BPMdata = analogRead(BPM);  // Read the PulseSensor's value.
                                              // Assign this value to the "Signal" variable.
   Serial.println(BPMdata);
  char  msg = BPMdata;
    driver.send((uint8_t *)msg, strlen(msg));
    driver.waitPacketSent();
    delay(200);
thanks
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you’re using the Arduino Web Editor you will not have access to this useful tool. I recommend you to use the standard IDE instead.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we’re trying to read your code.
When your code requires a library that’s not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
