Sending SD card files/data to pc
I am a newbie in the field of interfacing and commenucation. I was wondering if anyone could help me out with sending data stored on an SD card connected to an Arduino Uno to a pc using USB and COM ports on of the PC.
The data file would be multipile bytes which i want to use for further processing using the PC.
SD -> Arduino -> USB -> PC
There is DumpFile in the SD section of the IDE examples. That should be all you need. The file would go into a proper terminal programme, e.g. RealTerm.
thank you, i will try this later :slight_smile:
