So I have a tomato plant that i would like to measure the moisture level of and send the values to the internet. Really i just want a simple webpage or even a local ip address that i can type into a browser and view.
Here is the code for the sensor:
int moistureSensor = 0;
int moisture_val;
Serial.begin(9600); //open serial port
moisture_val = analogRead(moistureSensor); // read the value from the moisture-sensing probes
Serial.print("moisture sensor reads ");
Serial.println( moisture_val );
I would like to use this code but instead of viewing the info on my computer that it is hooked up to, set up the arduino on a power source and wirelessly send info to an ip or website.
