I will try and be as thorough as possible in describing my quandary.
I need to send serial (RS-232) commands from an automation control system (Crestron) to a photo spectrometer that only has a USB connection for power and communications.
I am using an Arduino Mega 2560, an Arduino USB host shield, and a spark fun RS-232 board that are connected to Tx/Rx3 (pin 14 & 15).
Using some codes that I’ve pilfered from available examples, I seem to have made a halfway working system. I can use the Arduino serial monitor to send the commands to the USB device and get the data to display in that window. I can also get that information to display in a second serial monitor window that i’ve setup by attaching the output of the spark fun RS-232 to my computer using a keyspan USB/RS232 adapter. What I cannot do is send commands from the second serial monitor through the arduino and to the attached spectrometer.
If anyone has any pearls of wisdom to shed on my quandary it would be greatly appreciated.
Thanks
Scott
* INCLUDE FILES
#include <cdcacm.h>
#include <usbhub.h>
#include "pgmstrings.h"
#include <SoftwareSerial.h>
* VARIABLES DEFINITION
unsigned char Cmd;
unsigned char i;
String CrestronCmd;
String incomingString;
* FUNCTION PROTOTYPES
// Satisfy the IDE, which needs to see the include statment in the ino too.
//#ifdef dobogusinclude
//#include <spi4teensy3.h>
//#include <SPI.h>
//#endif
SoftwareSerial myCrestron(15, 14); // RX, TX
class ACMAsyncOper : public CDCAsyncOper
public:
uint8_t OnInit(ACM *pacm);
uint8_t ACMAsyncOper::OnInit(ACM *pacm)
uint8_t rcode;
// Set DTR = 1 RTS=1
rcode = pacm->SetControlLineState(3);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SetControlLineState"), rcode);
return rcode;
LINE_CODING lc;
lc.dwDTERate = 115200;
lc.bCharFormat = 0;
lc.bParityType = 0;
lc.bDataBits = 8;
rcode = pacm->SetLineCoding(&lc);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SetLineCoding"), rcode);
return rcode;
USB Usb;
//USBHub Hub(&Usb);
ACMAsyncOper AsyncOper;
ACM Acm(&Usb, &AsyncOper);
* Setup - Do Once at Start of Program
// Init Serial Port
Serial.begin( 115200 );
myCrestron.begin(9600); // Start RS-232 Board
myCrestron.println("Arduino RS-232 Port Ready:");
incomingString = "";
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSCOKIRQ failed to assert");
delay( 200 );
* Main Program Loop
//***** Begin Crestron Code *****//
//Check if there's incoming serial data
if (myCrestron.available() > 0) {
//Read a byte from the serial buffer
char incomingByte = (char)myCrestron.read();
incomingString += incomingByte;
//Checks for null termination of the string.
if (incomingByte == '\0') {
Serial.println (incomingString);
//***** Begin Serial Monitor *****//
Usb.Task();
if( Acm.isReady()) {
uint8_t rcode;
/* reading the keyboard */
if(Serial.available()) {
uint8_t data= Serial.read();
/* sending to the phone */
rcode = Acm.SndData(1, &data);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SndData"), rcode);
}//if(Serial.available()...
delay(50);
/* reading the phone */
/* buffer size must be greater or equal to max.packet size */
/* it it set to 64 (largest possible max.packet size) here, can be tuned down
for particular endpoint */
uint8_t buf[64];
uint16_t rcvd = 64;
rcode = Acm.RcvData(&rcvd, buf);
if (rcode && rcode != hrNAK)
ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
if( rcvd ) { //more than zero bytes received
for(uint16_t i=0; i < rcvd; i++ ) {
Serial.print((char)buf[i]); //printing on the screen
myCrestron.print((char)buf[i]);
delay(10);
}//if( Usb.getUsbTaskState() == USB_STATE_RUNNING..
//***** End Serial Monitor *****//
