I'm having problems getting a C program to accurately read bytes from Arduino serial output. (Sending data from the C program to the Arduino works fine.) I eventually want to send a byte from C to tell Arduino to start a measurement, wait for the measurement to finish, and then read a float from the Arduino. I'm running this on an Ubuntu 12.
Arduino code:
if(Serial.available()){
int byteRead = Serial.read()-48;
Serial.println(byteRead);
Serial.write('a');
Serial.write('b');
Serial.write('c');
Serial.write('d');
Serial.write('1');
Serial.write('2');
Serial.write('3');
Serial.write('4');
Serial.write('\n');
C code:
#include <stdio.h> /* Standard input/output definitions */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <time.h>
#include <sys/types.h>
#include <stdlib.h>
#include <stdint.h> /* Standard types */
#include <sys/ioctl.h>
#include <getopt.h>
int main(){
printf("Hello World\n");
// Method 1
//Open communication with arduino
int portName = open("/dev/ttyUSB0", O_RDWR | O_NOCTTY | O_NDELAY);
struct termios options;
tcgetattr(portName, &options);
cfsetispeed(&options, B9600);
cfsetospeed(&options, B9600);
options.c_cflag |= (CLOCAL | CREAD);
tcsetattr(portName, TCSANOW, &options);
//8 bit characters
options.c_cflag &= ~CSIZE; /* Mask the character size bits */
options.c_cflag |= CS8; /* Select 8 data bits */
//No parity
options.c_cflag &= ~PARENB;
options.c_cflag &= ~CSTOPB;
//Send Take Sample command to arduino
char num[] = "3";
write(portName, num, 1);
printf("%s\n",num);
//Read Hb answer
unsigned char Hb[9];
int pos = 0;
while( pos < 10 ) {
read(portName, Hb+pos, 1);
if( Hb[pos] == '\n' ) break;
printf("%i ",pos);
printf("%x\n",Hb[pos]);
pos++;
printf("%i\n",pos);
Hb[4]='\0';
printf("Goodbye World\n");
//Close communication
close(portName);
return 0;
The expected output would be:
Hello World
3
0 61
1 62
2 63
3 64
4 31
5 32
6 33
7 34
8
8
Goodbye World
The current output is
Hello World
3
0 b7
1 0
2 0
3 0
4 0
5 e9
6 88
7 4
8 8
9 0
10
Goodbye World
Any suggestions? I'm sure this is a solved problem, but I haven't been able to figure it out. Thank you for the help!
