sending serial data from Matlab to shift registers
Hello,
I am working on a project that continuously turns 256 water jets (LEDs, for forum purposes...) on and off using 1 Arduino and 32 shift registers (each of which controls 8 of the jets/LEDs). The algorithm to determine which jets go on/off continuously updates in Matlab. I then form the 32 bytes to send via serial from Matlab to the Arduino (and it gets sent to each shift register in turn). In theory, very straightforward.
My serial code works to send the bytes from Matlab to the Arduino. However, once read into the Arduino, I can print these digits back out but they are not activating the shift registers. I think the shift register is seeing them as strings instead of ints, but do not know if that's the problem, nor how to fix it. Any ideas? I tried simple "atoi" stuff with no luck, but very open to suggestions!
Simplified but functioning Matlab serial portion of script:
data1=28;
data2=52;
x=1;
s = serial('/dev/tty.usbmodem411','BaudRate',19200)
fopen(s)
while x<4
fprintf(s,'%d ',data1);
fprintf(s,'%d ',data2);
x=x+1;
pause(0.5)
end
fclose(s);
delete(instrfindall);
Simple Arduino code attached, for 2 shift registers at a time: note, this will print "28" and "52" several times, but no LEDs light up. whereas if I typed directly:
shiftOut(dataPin, clockPin, MSBFIRST, 28);
shiftOut(dataPin, clockPin, MSBFIRST, 52);
then I do see success. ideas???
Thank you!!
sketch_aug18a.ino (1.2 KB)
update: realized my error -- shiftOut was only happening once; the ints "seq1" and "seq2" were adequately getting updated but not actually going out to the shift registers! i did this to synchronize the timing, so that the latching would happen immediately upon reaching the next time increment, but there are better ways to do this. so -- resolved for now, but probably to be continued once things get more complicated with the next steps!
