Hi there,
I guess I found a new way to try send SMS from Arduino. Found this from http://www.instructables.com/id/Send-SMS-from-Arduino-over-the-Internet-using-ENC2/?ALLSTEPS. It stated that I can change a little bit from the program to make it work with wifi shield but it seems that my program is not running when it was already uploaded to Arduino.
Here's my code:
#include <SPI.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
//thingspeak server
char server[] = "api.thingspeak.com";
char ssid[] = "SSID";
char pass[] = "PASS";
WiFiClient client;
//API key for the Thingspeak ThingHTTP already configured
const String apiKey = "API_KEY";
//the number the message should be sent to
const String sendNumber = "PHONE_NUMBER";
setupWiFi();
//send the sms
Serial.println("Sending SMS");
//this function will send the sms
//the first argument is the number to send to, formatted like this +12345678901
//the second argument is the body of the text message, which must be within URLEncode()
sendSMS(sendNumber, URLEncode("Hello World!"));
void sendSMS(String number,String message)
// Make a TCP connection to remote host
if (client.connect(server, 80))
//should look like this...
//api.thingspeak.com/apps/thinghttp/send_request?api_key={api key}&number={send to number}&message={text body}
client.print("GET /apps/thinghttp/send_request?api_key=");
client.print(apiKey);
client.print("&number=");
client.print(number);
client.print("&message=");
client.print(message);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println();
Serial.println(F("Connection failed"));
// Check for a response from the server, and route it
// out the serial port.
while (client.connected())
if ( client.available() )
char c = client.read();
Serial.print(c);
client.stop();
void setupWiFi()
Serial.println("Setting up WiFi...");
//start wifi connection
WiFi.begin(ssid, pass);
Serial.print("Connected to SSID: ");
Serial.println(ssid);
String URLEncode(const char* msg)
const char *hex = "0123456789abcdef";
String encodedMsg = "";
while (*msg!='\0'){
if( ('a' <= *msg && *msg <= 'z')
|| ('A' <= *msg && *msg <= 'Z')
|| ('0' <= *msg && *msg <= '9') ) {
encodedMsg += *msg;
else {
encodedMsg += '%';
encodedMsg += hex[*msg >> 4];
encodedMsg += hex[*msg & 15];
msg++;
return encodedMsg;
the message stated on my serial monitor is:
Setting up WiFi...
Attempting to connect to WEP network, SSID: iotlab
Sending SMS
H
any idea what is wrong here? Message seem not able to get through my phone. Appreciate for your time in helping. Thanks in advance.
Hazirah
