Hello all, still fairly new to programming in general, but I am getting frustrated so I'm asking for help. I wrote a program in processing to display and keep track of the state of a grid of 64 buttons. The buttons "turn on and off" with a mouse click and the state of all 64 buttons is sent over serial when a keyboard button is pressed. I'm hoping to set the state of an LED matrix connected to the arduino when the serial message is received by the arduino. Right now I'm testing that the serial message is sent and received correctly. The arduino sketch has a for loop that populates an array with the values received by serial when there is at least 63 bytes available in the serial buffer on the arduino. As of right now, all of the buttons populate the array correctly except the 64th button. Am I missing something stupid here or am I not understanding how the serial transmission is happening?
Here is the code for the arduino:
int buttonState[64];
pinMode(12, OUTPUT); // Set pin as OUTPUT
pinMode(11, OUTPUT); // Set pin as OUTPUT
pinMode(10, OUTPUT); // Set pin as OUTPUT
pinMode(9, OUTPUT); // Set pin as OUTPUT
Serial.begin(19200); // Start serial communication at 19200 bps
if(Serial.available() >= 63) {
for(int b=0;b<64;b++){
buttonState[b] = Serial.read();
if (buttonState[0] == 1) { // If 1 was received
digitalWrite(12, HIGH); // turn the LED on
if (buttonState[63] == 1) { // If 1 was received
digitalWrite(11, HIGH); // turn the LED on
delay(10);
Here is the processing sketch:
import processing.serial.*;
PrintWriter output;
Serial myPort; // Create object from Serial class
int rectSize = 50;
color[][] rectColor;
boolean[][] rectOver;
int[][] buttonState;
int[][] rectX;
int[][] rectY;
//int[][] send;
int side = 8;
int count = 0;
rectColor = new color[side][side];
rectOver = new boolean[side][side];
rectX = new int[side][side];
rectY = new int[side][side];
//send = new int[side][side];
buttonState = new int[side][side];
size((side*(rectSize+10)), (side*(rectSize+10)));
for(int j=0;j<side;j++){
for(int k=0;k<side;k++){
rectColor[j][k] = color(0);
rectX[j][k] = (j*(rectSize+10))+5;
rectY[j][k] = (k*(rectSize+10))+5;
rectOver[j][k] = false;
buttonState[j][k] = 0;
//send[k][j] = count;
count++;
//println(Serial.list());
String portName = Serial.list()[0];
myPort = new Serial(this, portName, 19200);
output = createWriter("positions.txt");
void draw() {
update(mouseX, mouseY);
background(127);
for(int n=0;n<side;n++){
for(int o=0;o<side;o++){
fill(rectColor[o][n]);
rect(rectX[o][n], rectY[o][n], rectSize, rectSize);
void update(int x, int y) {
for(int s=0;s<side;s++){
for(int t=0;t<side;t++){
rectOver[t][s] = false;
if ( overRect(rectX[t][s], rectY[t][s], rectSize, rectSize) ) {
rectOver[t][s] = true;
void mousePressed() {
for(int q=0;q<side;q++){
for(int r=0;r<side;r++){
if (rectOver[q][r] && buttonState[q][r] == 0) {
rectColor[q][r] = color(255);
buttonState[q][r] = 1;
//myPort.write(send[q][r]);
else if (rectOver[q][r] && buttonState[q][r] == 1) {
rectColor[q][r] = color(0);
buttonState[q][r] = 0;
//myPort.write(send[q][r] + 64);
void keyPressed() {
myPort.clear();
for(int a=0;a<8;a++){
for(int b=0;b<8;b++){
myPort.write(buttonState[b][a]);
output.print(buttonState[b][a]);
output.flush(); // Writes the remaining data to the file
output.close(); // Finishes the file
exit(); // Stops the program
boolean overRect(int x, int y, int width, int height) {
if (mouseX >= x && mouseX <= x+width &&
mouseY >= y && mouseY <= y+height) {
return true;
return false;
