I have arduino uno board .I &my batch is making the project of "finger print based attendances management system" we have a program, it working & we use the stored device of the microcontroller EEPROM .But the problem is 'How to send the data arduino uno to pc's excel sheet?' . Please tell me about of any code, softwares .it helps to our project.
You need a SD-card and a SD-card module for the arduino, then you can store it on a .txt file on the SD-card and transfer that file to Excel.
You could also format that data as a comma separated list (csv file) which you could then use on your PC and import into Excel.
A comma separated list has the format (example):
"transactionNumber","temperature","lightIntensity","comment"
1,22,200,"dark"
2,23,750,"reading late"
2,25,600,""
You migth be in the position to send the data direct to Excel, and have Excel timestamp it with the PC clock.
No EEPROM needed,
No SD needed, and
No clock needed
Just how much research have you done? Never mind. I already know the answer.
Do some!
