Sending String from Arduino Uno to Vb.net Using Firmata
Hi every one…
I would like to send string from Uno to Vb.net .
EchoString.pde
/* This sketch accepts strings and raw sysex messages and echos them back.
 * This example code is in the public domain.
#include <Firmata.h>
byte analogPin;
void stringCallback(char *myString)
    Firmata.sendString(myString);
void sysexCallback(byte command, byte argc, byte*argv)
    Serial.print(START_SYSEX, BYTE);
    Serial.print(command, BYTE);
    for(byte i=0; i<argc; i++) {
        Serial.print(argv[i], BYTE);
    Serial.print(END_SYSEX, BYTE);
    Firmata.setFirmwareVersion(0, 1);
    Firmata.attach(STRING_DATA, stringCallback);
    Firmata.attach(START_SYSEX, sysexCallback);
    Firmata.begin(9600);
    while(Firmata.available()) {
        Firmata.processInput();
And in Vb.net
Public Class Form1
Private Sub SimpleButton1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SimpleButton1.Click
        FirmataVB1.Connect("COM14", 9600)
        FirmataVB1.QueryVersion()
        MsgBox(FirmataVB1.SerialPort1.ReadLine)
            MemoEdit1.Text = (FirmataVB1.SerialPort1.ReadLine).ToString
        MsgBox("COnnect")
    End Sub
End Class
When i try to connect…vb.net return nothing, only waiting for the responding until error occurs.
Anyone knows how to solve the problem?
thanks.
did you get ot the bottom of this ?
There are some issues with COM ports 10 and above, with some software. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1192119372 show how to define the name of a port 10 or above. Perhaps this will make a difference.
For those who have problems with Firmata's sysex and want to acess sysex comands easily:
Try http://connect.mind-craft.net/arduino-firmata-vb-class - change "storedInputData" variable to public and use it, e.g.:
Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
        arduino1.StartSysex()
        arduino1.mycommand1(20, 1)
        arduino1.EndSysex()
        Thread.Sleep(100) 'Delay less than a second
        arduino1.processInput()
        TextBox1.Text = arduino1.storedInputData(1)
End Sub
use https://github.com/jgautier/arduino-1/blob/master/examples/EchoString/EchoString.ino and read http://firmata.org/wiki/Protocol to add your own sysex command to Arduino.vb
