Sending String from HC05 to HC06
Hey all, I'm trying to get my two Arduino Unos to communicate by sending a String from the Arduino connected to the HC05 unit and for the HC06 to receive it. The bluetooth modules are configured correctly, but with the code, all that is received is
X
X
X
X
18
ø€€€€ø€ø€€€€€€€ø€€
X
X
X
18
ø€€€€ø€ø€€€€€€€ø€€
over and over again. I completely understand why the 'X's are there, but I don't understand why the length is 18 and the input is garbage.
The SoftwareSerials communicate using the bluetooth and the Serial communicates to my computer.
My sending and receiving code is below:
Sending:
#include <SoftwareSerial.h>
SoftwareSerial ss(9,8); // RX, TX -> TX, RX
  ss.begin(9600);
char inChar = ' ';
String inString = "";
  String color = "S255000000S\n";
  inString = "";
  ss.print(color);
  Serial.print(color);
  while(ss.available()>0){
    Serial.println("WORKING!");
    inChar = ss.read();
    inString += inChar;
  if(inString.length() >= 2){
    Serial.println(inString);
Receiving:
  ss.begin(9600);
char inChar = ' ';
int color[3] = {0,0,0};
  inString = "";
    inChar = ss.read();
    inString += inChar;
    delay(4);
  ss.println("X");
  Serial.println("X");
  if(inString.length() > 0){
    Serial.println(inString.length());
Put about 2 more hours of work into this with no avail, anybody have any ideas?
Try simplifying the whole thing, for sending :
	char test[] = "test";
	ss.print( test );
	delay( 1000 );
for recieving:
		Serial.print( ss.read() );
Does this work?
Look at the examples in serial input basics. The third example is the most reliable and you should match your sending code to it.
For example ss.print("");
Get something simple like that working before you do anything more complicated.
It is not a good idea to use Strings (capital S) in the small memory of an Arduino. Just use strings (small s) which are char arrays with a '\0' terminator.
...R
