Sending string to Arduino uno using UART
I'm trying to communicate between Arduino uno and Jetson Nvidia tk1 using UART by sendng message from Jetson kit to Arduino and blinking a led connected to Arduino when I recieve this message, but I have problem when to recieve this message
I send my message from Jetson tk1 using the following function
write(int fildes, const void *buf, size_t nbyte) from unistd library
buf contains the message that I want to send and this message is the word "stop"
I'm sure that this function sends my message correctly but not sure if I receive it correctly or not
The code I used to receive this message is
String msg;
      pinMode(13, OUTPUT);
   if(Serial.available()>0)
      msg = Serial.readString();
      if(msg == "stop")
            digitalWrite(13,HIGH);
The compiler doesn't give me errors when I upload the code on Arduino but still the led doesn't blink as I want it which means that it didn't receive the word stop.
I hope someone can help me to solve this problem
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
...R
if(msg == "stop")
digitalWrite(13,LOW); // not HIGH
