Sending String with MyPort.write from processing to arduino.
I am trying to send a String from processing to my arduino with no succes.
I can send "char variable" but it wont send a string.
processing code (sending char, WORKS)
import processing.serial.*;
Serial myPort;  // Create object from Serial class
  size(200, 200); //make our canvas 200 x 200 pixels big
  String portName = Serial.list()[0]; //change the 0 to a 1 or 2 etc. to match your port
  myPort = new Serial(this, portName, 9600);
void draw() {
  if (mousePressed == true)
  {                           //if we clicked in the window
    myPort.write('1');         //send a 1
    println("oussama");
  } else
  {                           //otherwise
    myPort.write('0');          //send a 0
Arduino code(sending char, WORKS)
char val; // Data received from the serial port
int ledPin = 3; // Set the pin to digital I/O 13
  pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
  Serial.begin(9600); // Start serial communication at 9600 bps
  if (Serial.available())
  { // If data is available to read,
    val = Serial.read(); // read it and store it in val
  if (val == '1')
  { // If 1 was received
    digitalWrite(ledPin, HIGH); // turn the LED on
    digitalWrite(ledPin, LOW); // turn the LED on
    digitalWrite(ledPin, LOW); // otherwise turn it off
  delay(10); // Wait 10 milliseconds for next reading
When i try to send an String with myPort.write: processing(sending String, DOES NOT WORK)
void draw() {
    myPort.write("test");         //send a 1
    println("oussama");
  } else
  {                           //otherwise
arduino(sending String, DOES NOT WORK)
String val; // Data received from the serial port
  if (val == "test")
Can anyone help me with this?
I cant run both programs at the same time so i don't know what the processing is sending to my device.
What proof do you have that the string is not sent?
  if (val == "test")
Serial.read() reads one character. One character will never equal "test". Using == is not how to compare strings, if you were to collect the characters that Processing sends into a NULL terminated array of chars.
http://forum.arduino.cc/index.php?topic=396450.0
Ima check it out thanks alot!
I found a solution using this do while loop.
String inputread;
  inputread = "";
    do{
      if (val != -1){
        inputread = inputread +val;
      }while(val != -1);
  if (inputread == "kkk")
