Sending struct through serial1
I'm using MKRZero to send data to other board through serial1 (both boards have rf module)
I wrote this function to send a struct to the other board but I'm getting error while compling :
void sendRequestToMaster()
header_S hdrSend;
hdrSend.sendRecieve = 1;
hdrSend.gatewayID = GATE_WAY;
hdrSend.sensorID = 0;
hdrSend.msgType = AskForSend; // request
hdrSend.msgSize = 0;
  Serial1.write(hdrSend, sizeof(header_S));
error massege :
C:\Users\User\Documents\Arduino\GateWaySketches\AskForSend\AskForSend.ino: In function 'void sendRequestToMaster()':
AskForSend:89:46: error: no matching function for call to 'Uart::write(header_S&, unsigned int)'
In file included from C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\variants\mkrzero/variant.h:162:0,
             from C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/Arduino.h:48,
             from sketch\AskForSend.ino.cpp:1:
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/Uart.h:40:12: note: candidate: virtual size_t Uart::write(uint8_t)
 size_t write(const uint8_t data);
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/Uart.h:40:12: note: candidate expects 1 argument, 2 provided
In file included from C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/ArduinoAPI.h:31:0,
             from C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/Arduino.h:23,
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:55:12: note: candidate: size_t arduino::Print::write(const char*, size_t)
 size_t write(const char *buffer, size_t size) {
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:55:12: note: no known conversion for argument 1 from 'header_S' to 'const char*'
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:54:20: note: candidate: virtual size_t arduino::Print::write(const uint8_t*, size_t)
 virtual size_t write(const uint8_t *buffer, size_t size);
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:54:20: note: no known conversion for argument 1 from 'header_S' to 'const uint8_t* {aka const unsigned char*}'
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:50:12: note: candidate: size_t arduino::Print::write(const char*)
 size_t write(const char *str) {
C:\Users\User\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.11\cores\arduino/api/Print.h:50:12: note: candidate expects 1 argument, 2 provided
exit status 1
How about
(Sorry, I can't remember what sort of pointer write requires, and I'm away from a PC at the moment)
Nope it didn't work.
Try char* instead of void*
