Sending structs through serial, getting errors
I'm using MKRZero to send data to other board (MKR GSM 1400 )through serial1 (both boards have rf module).
I'm sending the data using struct, both code for recieving and sending have the exact struct.
Sometimes I get the massege correct but sometimes I don't, and I honestly don't know why..
The code for receiving the struct:
int incomingData;
  enum msg_type {AskForSend, Ack, Data, Error, Stop};
  struct header_S
    byte sendRecieve;
    byte gatewayID;
    byte sensorID;
    msg_type msgType;
    byte msgSize;
    int Data;
   delay(2000);
   Serial1.begin(9600);
void loop () {
  if (Serial1.available() > 0)
    incomingData = Serial1.available();
    Serial.print("byte we need to recieve : ");
    Serial.println(incomingData);
    HandleGatewayMsg();
void HandleGatewayMsg()
  header_S hdr;
  byte *hdr_ptr;
  hdr_ptr = (byte *)&hdr;
  Serial.println("Msg recieved...");
  Serial1.readBytes(hdr_ptr, sizeof(header_S));
  Serial.println(hdr_ptr[0]);
  Serial.println(hdr_ptr[1]);
  Serial.println(hdr_ptr[2]);
  Serial.println(hdr_ptr[3]);
  Serial.print("MsgType: ");
  Serial.println(hdr.msgType);
    switch(hdr.msgType)
      /*case AskForSend:
        Serial.print("Got a request from gateway..");
        SendAck(hdr.gatewayID); //send ack msg
        break;    */
       case Data:
        Serial.println("Recieved data from gateway..");
        Serial.print("temp = ");
        Serial.println(hdr.Data);
The code for sending the massage :
#include "Adafruit_Sensor.h"
#include "Adafruit_AM2320.h"
Adafruit_AM2320 am2320 = Adafruit_AM2320();
#pragma pack (1)
unsigned int start_time;
int timeoutMeasure = 2*60*1000;
int temp; // Global variable
struct header_S
  byte sendRecieve;
  byte gatewayID;
  byte sensorID;
  msg_type msgType;
  byte msgSize;
  int Data;
  while (!Serial) {
    delay(10); // hang out until serial port opens
  am2320.begin();
  if (millis() - start_time > timeoutMeasure)
          HandleSensorData();
          start_time = millis();
void HandleSensorData(){
  Serial.println("Getting data from sensors");
  temp = am2320.readTemperature();
  Serial.println(temp);
  sendDataToMaster();
void sendDataToMaster( )
      Serial.println("Sending Data to master...");
      Serial.print("Numbers of bytes on the msg : ");
      Serial.println(sizeof(header_S));
      header_S hdrSend;
      hdrSend.sendRecieve = 1;
      hdrSend.gatewayID = 1;
      hdrSend.sensorID = 1;
      hdrSend.msgType = Data;
      hdrSend.msgSize = sizeof(int);
      hdrSend.Data = temp ;
      Serial1.write((byte*)&hdrSend, sizeof(header_S));
      Serial.println(((byte*)&hdrSend)[0]);
      Serial.println(((byte*)&hdrSend)[1]);
      Serial.println(((byte*)&hdrSend)[2]);
      Serial.println(((byte*)&hdrSend)[3]);
This the serial monitor on the MKR GSM 1400 (The board that should receive the data) :
What tells you that a full message was received? Maybe only process the data if you have received the correct number of bytes?
I would also add a mechanism to handle synchronisation.
Don’t post snippets (Snippets R Us!)
I don't think they are snippets; what do youthink that is missing?
I figured it out, one of the gnd's cable wasn't working properly, sorry for the inconvenience.
My bad - for some reasons I was not seeing the full code
