Sending Sysex with arduino uno, hiduino, midi lib
Hello.
I am programming an Uno board with hiduino firmware installed for a midi usb controller.
I am using midi monitor on my mac to monitor midi messages send by arduino.
I can send midi notes, programm change, control change without problems.
But when I'm triying to send sysex, something doesn't work.
With the code below, I send F0 7F 01 06 02 F7 but in midi monitor I get two midi messages arriving:
F0 F7
F0 F7
// Include library
#include <Bounce2.h>
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define BUTTON_PIN 2
// Define Sysex
byte data[] = { 0xF0, 0x7F, 0x01, 0x06, 0x02, 0xF7 };
// Instantiate a Bounce object
Bounce debouncer = Bounce();
// Setup the button with an internal pull-up
pinMode(BUTTON_PIN,INPUT_PULLUP);
// After setting up the button, setup the Bounce instance
debouncer.attach(BUTTON_PIN);
debouncer.interval(5); // interval in ms
MIDI.begin();
// Update the Bounce instance
debouncer.update();
// Call code if Bounce fell (transition from HIGH to LOW) :
if ( debouncer.fell() ) {
// Send midi
MIDI.sendSysEx(6, data, true);
Bump, I'm experiencing the same issue with my HIDuino setup. Has anyone experienced this or know what could be causing the above issue? Any help would be appreciated!
Pat
This happened to me too!
Same setup, Arduino UNO, with HIDUINO flashed on the atmega16u2, using Arduino MIDI Library.
Maybe it's time for a post in the respective Githubs?
